Engine Specific Info and Questions > mTDI Mechanical TDI Conversions
1.9 ALH Timing with pulse adapter and timing light help
fatmobile:
Sure, when you know where the TDC window is supposed to be.
Make it and mark the flywheel at 12BTDC.
libbydiesel:
My timing light has the advance function so there is no need to ever mark the flywheel (other than actual TDC). Just change the advance setting on the light to 12° and adjust the pump until the pulse happens when the TDC mark is aligned with the pointer.
ORCoaster:
That is how I use my timing gun. Set it and push or pull on the IP and line up the TDC mark accordingly. So simple.
fatmobile:
Good point libby.
I forgot mine has that feature, I've never used it.
Navigation
[0] Message Index
[*] Previous page
Go to full version
