NOS CY condition
Topic: NOS CY condition (Read 4246 times)
June 25, 2023, 11:17:17 am
oblique
Diesel while you can.
NOS CY condition
June 25, 2023, 11:17:17 am »
Some mixed photos here before and after...the 'befores' are at bottom. The deck as it came out of the along with rust on #2, then after sanding the surface with 400 grit and cleaning up #2 with same...I can't feel any of the discoloration with my fingernail, the worst of it was below the top ring line at top of piston travel. I haven't removed pistons to check rings but I assume they may need to be changed.
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
June 25, 2023, 01:29:48 pm
RustyCaddy
Re: NOS CY condition
June 25, 2023, 01:29:48 pm »
Seemed to cleanup pretty well. Nice find!
June 25, 2023, 09:18:58 pm
June 25, 2023, 09:18:58 pm »
That looks like it will be a good runner.
The little rust marks in the one cylinder might cause some grief but it should run great.
Someone suggested that putting cut-down sour cream containers in the bores can keep stuff from falling into them.
I think cutdown oykos yoghurt cups fit well too and are a little shorter.
It helps me clean the surface and chase the bolt holes without worrying about stuff falling down into the bores.
June 26, 2023, 09:51:50 am
oblique
June 26, 2023, 09:51:50 am »
I don't know how water got into this motor. It was in a thick plastic bag in a sturdy double-walled VW box...they are packed upside down (deck facing down) so that's where is settled but it is odd.
The worst corrosion seems to be below the top ring line so it should be ok to all but the most particular. I do have new rods and crank for this thing along with a new mech head but who's going to pay freight for a 40 yo motor? I have the old-school timing covers as well I think.
Last Edit: June 27, 2023, 08:02:43 pm by ORCoaster
90 1.6TD Jetta
79 1.6Na Rabbit
NOS CY condition
