Model Specific Questions and Info > MK2 Golf/Jetta and Audi 5k
CE2 resistors on cluster
fatmobile:
Measure the voltage at the sender.
I think it's supposed to be around 11 volts but really not sure.
I'll have to check mine.
That should tell you if there are voltage drops at connections etc.
I think as resistance goes down, current increases and the needle goes up.
Have you checked the ground from the instrument cluster?
If a ground wire has voltage on it,..
it's not grounded.
Navigation
[0] Message Index
[*] Previous page
Go to full version
