Author Topic: New low sulphur diesel warning!  (Read 18354 times)
Reply #15August 18, 2006, 01:30:36 pm
commuter boy
  • 277
« Reply #15 on: August 18, 2006, 01:30:36 pm »
Hmm.  That may explain why Giles said he got 5 pumps in last week for overhauls and performance builds when he usually only gets a trickle.
Reply #16August 18, 2006, 02:51:09 pm
anarchyx34
« Reply #16 on: August 18, 2006, 02:51:09 pm »
Quote from: jackbombay
If you put low sulpher diesel in a car that requires Ultra low sulpher diesel it will wreck the emissions equipment, it can't wreck the engine itself.
So where do you fuel up if you've got a 07 or newer vehicle?
Reply #17August 18, 2006, 05:40:23 pm
jimbrown618
  • 43
« Reply #17 on: August 18, 2006, 05:40:23 pm »
So I guess the bottom line is that we should be using an additive at every fillup? I was using Stanadyne but just switched to Power Sevice. I have a 97 Golf TD with 358K and have been having no problems so far...)knock on wood...).
Reply #18August 18, 2006, 07:17:32 pm
zagarus
  • 619
« Reply #18 on: August 18, 2006, 07:17:32 pm »
I just decided to try Diesel Aid, seems to be working pretty good, my car always has full potential (unlike other times when it feels unusually gutless).  I bought it at a local Western Star/Sterling shop.  on little 8oz bottle treats 240ish gallons, and i put in 1/4 into a what? 12 gallon tank? :lol:
Reply #19August 21, 2006, 06:46:56 pm
zyewdall
  • 393
« Reply #19 on: August 21, 2006, 06:46:56 pm »
Basically, it looks like we'll be going through the same issue with diesel's in the next few years that gas engines went through with leaded and unleaded gas back in the 70's.   Two types of fuel -- the old stuff kills the catalytic converters on the new ones, and the new stuff destroyes the engines on the old ones......    :roll:     And all of us driving old diesels will keep a can of lubricity booster in the trunk, just like everyone used to have a can of lead substitute in their car for years (I still have a truck that doesn't take unleaded gas, but I'm changing it to electric drive soon).
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #20August 23, 2006, 11:56:08 am
QuickTD
  • 1156
« Reply #20 on: August 23, 2006, 11:56:08 am »
We went though all this back in the early 90's, with the switch to low sulpher diesel. The lack of lubricity killed a few borderline pumps, mostly stanadyne and CAV rotaries. Seal shrinkage caused some leaks. The refiners added lubricity additives and the issue was mostly forgotten. Armed with this experience I would hope that the refiners would take the necessary steps to deal with the lubricity issue this time around.
Reply #21August 24, 2006, 03:38:01 pm
« Reply #21 on: August 24, 2006, 03:38:01 pm »
I use power service.  Good stuff!  Makes my car a bit accel a bit faster by boosting the cetane too.
I'm wondering about notching my gas tank filler neck for a little hose.. so I can hook up a little spray pump (the stuff stinks...) to spray before I pump the diesel.  Hook up a washer pump... 1 pulse would probably do it right?  :)
Reply #22August 25, 2006, 05:31:47 pm
VW Scully
  • 245
    • Not Quite Tom Riddle's Diary
« Reply #22 on: August 25, 2006, 05:31:47 pm »
It would make much more sense to have Biodiesel or a blend instead of the ULSD crap; it would solve BOTH problems!  :roll:  (lubricity and lower emissions)  :D
Tara aka VW Scully
**1981 Rabbit Diesel L, Biodiesel driven: 'the Bio-Bunny' **
Advocate for Young Adult Cancer Research & Support: I'm too Young for This!!
http://www.i2y.com
Reply #23August 28, 2006, 03:07:47 am
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« Reply #23 on: August 28, 2006, 03:07:47 am »
IN THEORY, the ultra low sulfur fuel should have enough lubricity - they have to meet a lubricity specification. If it doesn't meet that specification, then the station owes you an injection pump. But I don't think lubricity is the problem here...
I think what you all are seeing is seal shrinkage, due to there being less aromatics in the fuel. The issue is, those aromatics caused your seals to swell back in the day, and then crush themselves. When the aromatics go away, the seals shrink... but they're crushed, so now they don't seal. This is also the source of all of the "oh noes, biodiesel made my injection pump leak" stuff.
Fully rebuild your pump, go on with life, and don't touch low sulfur fuel once this happens.
Or, if you're really worried about it, use the old-school Cummins trick back from 1993. Automatic transmission fluid. Not sure how much to use, though. Don't go overboard, as you don't want to make it high sulfur - you're trying to bring it back to 500 ppm, from 15 ppm, not 5000 ppm from 500. ;)
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #24August 28, 2006, 08:36:30 am
935racer
« Reply #24 on: August 28, 2006, 08:36:30 am »
The low sulphur fuel DOES NOT have enough lubricity, one of my local fuel injection shops has been playing around with the new low sulphur fuel for a while now, the process they use to make the low sulphur fuel decreases the lubricity drastically.
ATF will work, 2 stroke oil works much better, as it is designed to MIX with fuel.
Reply #25August 28, 2006, 07:07:58 pm
« Reply #25 on: August 28, 2006, 07:07:58 pm »
How much 2 stroke oil should be added per liter?
Reply #26August 28, 2006, 07:50:07 pm
« Reply #26 on: August 28, 2006, 07:50:07 pm »
run it on straight 2 stroke oil, it's cheaper
Reply #27August 28, 2006, 11:20:19 pm
935racer
« Reply #27 on: August 28, 2006, 11:20:19 pm »
1 OZ to 10 gallons.
Reply #28August 29, 2006, 11:02:23 am
zyewdall
  • 393
« Reply #28 on: August 29, 2006, 11:02:23 am »
Quote from: jtanguay
It stinks worse than diesel?   Diesel smells bad enough.    I'm used to B100, and I had to fill up a car with gasoline this week -- didn't realize what a stinky process that is.  You get spoiled using biodiesel all the time.  Although, most people think that biodiesel is what smells funny.
Reply #29September 11, 2006, 06:29:44 pm
« Reply #29 on: September 11, 2006, 06:29:44 pm »
Here's some good reading on the low sulfer diesel. Might be slightly Biased though
http://www.chevron.com/products/prodserv/fuels/diesel/
