Model Specific Questions and Info > MK2 Golf/Jetta and Audi 5k
Tricks to Remove Exhaust "C" Spring Clamps????
ORCoaster:
yepper, just need to get some sort of straight piece across the U shape to force the clamp apart.
fatmobile:
I think you are better off with a curved piece.
Like the exhaust clamp has when you flip it.
zip1916:
There really isn't a good trick you can do. Removing them is easy, as you can just pry them off with a screw driver. Getting them back on is the hard part. Especially on the turbo side (assuming you have a turbo diesel). The OEM tool for the job costs about 14$ in my country, in my local tool shop. If would advise you to get it.
ORCoaster:
zip1916, I object, using a simple muffler clamp as an expander instead of a clamp is the best trick there is. What's a clamp cost these days? 8 bucks?
Navigation
[0] Message Index
[*] Previous page
Go to full version
