Author Topic: Heat Shield Usage for Compresson Test  (Read 12394 times)
Reply #15November 11, 2020, 09:12:09 am
thomas m
  • 144
Re: Heat Sheild Usage for Compresson Test
« Reply #15 on: November 11, 2020, 09:12:09 am »
Something that I have noticed. Please correct if I'm wrong. Due to the difference in dimension from the threaded portion to the seat, a different portion of the adapter thread will engage. Assuming that all of the  glow plug thread engages an adequate amount of adapter will probably engage as shown in my sketch. But, still, care must be taken not to over torque the adapter since less thread is engaged. 22 foot pounds is probably not required to run the compression test. Just a snug fit may do. I just don't know. Test fitting with a little anti seize might show how much thread is engaged????/
Worst case, not all of the glow plug thread is engaged when seated so even less of the adapter thread will engage lessening its ability to take the torque without damaging the threads in the head. Spec torque for the glow plugs is 22 foot pounds .
It's nice to know that the injector and its adapter can take the 51 foot pounds required to seat the injector or adapter. I'm not so sure about the glow plug adapter. Caution advised.
« Last Edit: November 11, 2020, 09:14:43 am by thomas m »
Thomas, Original owner since new:
1991 MK2 Jetta Non-turbo 1.6 diesel, Engine Code ME, 5 speed 020 AWY 04120 transmission, Hydraulic Lifters,
320,000 miles
LOOKING FOR REBUILD OPTIONS IN PORTLAND, OR OR ON THE WEST COAST
Reply #16November 11, 2020, 09:39:36 am
« Reply #16 on: November 11, 2020, 09:39:36 am »
That looks like enough thread engagement to be strong.  No harm in being cautious, though.
One other interesting thought on making the HF kit more accurate...  Drill out the existing IDI injector adapter and tap it so that one of the glow plug adapters will fit into it with the check valve near the tip.
Reply #17November 11, 2020, 02:23:38 pm
« Reply #17 on: November 11, 2020, 02:23:38 pm »
I thought I would mention that just before this thread started I ordered the CTA 2800 diesel compression tester kit from Tool Discounter.  Shipped it was a little under $90.  It arrived yesterday.  It comes with three adapters.  One of them fits the IDI injectors perfectly.  It has a schrader valve in the tip.  I have not tested engine compression but did the 100 psi air pressure test and it passed showing 100 psi on the gauge.  The reason I got the kit was that I wanted a tester that worked well with the TDI engines.  One of the three adapters that comes with the kit is long and has the appropriate thread pitch for the TDI glow plugs, along with having the schrader valve in the top of the adapter.  The layout of the threads on the adapter is not quite right, though.  In order to get it to fit correctly, I needed to tap new threads another 1/4" or so onto the blank of the adapter.  I then needed to trim the threads near the tip of the adapter ~1/2".  I already had the 10mm x 1.0 die for cutting the threads and it was quite easy to accomplish.
This stolen pic shows the parts in the kit.  They all come in a plastic case.
This is a closeup of the two adapters I will use for VW's:
This shows the modification I needed to do to the long adapter in order for it to work with the TDI glow plug locations.  The black pen shows where the threads initially extended to toward the top.  I had to remove the threads from that end for the adapter to thread in far enough.  The gray pen shows where the threads were initially cut to.  I had to add the threads beyond that point in order for it to be able to thread in far enough:
Reply #18November 11, 2020, 08:59:31 pm
« Reply #18 on: November 11, 2020, 08:59:31 pm »
Nice and Brassy.  I like it!
May be looking at tapping the Injection adapter to add the Schrader valve.  That would make it right.
Reply #19November 12, 2020, 09:31:38 am
thomas m
  • 144
« Reply #19 on: November 12, 2020, 09:31:38 am »
Is that the HF adapter to which you are referring?? Let us know how that goes. Here's a brochure from Schrader-Pacific.com
https://www.schrader-pacific.com/media/pdf/Valve%20Core%20Brochure.pdf
 that has some  specifics on the tap dimensions and tools required. I don't know, maybe you have a simpler way to fit the valve. Based on my quick search, the hole in the HF injector adapter may be too big.
« Last Edit: November 12, 2020, 10:33:28 am by thomas m »
320,000 miles
Reply #20November 12, 2020, 09:32:02 pm
« Reply #20 on: November 12, 2020, 09:32:02 pm »
 The CTA 2800 diesel compression tester kit from Tool Discounter in the pic from Libby.  No black steel there.  Just shine and quality.
Might be something to think about there.  If it looks dark and dingy maybe avoid it for the bling down the aisle.
Reply #21November 13, 2020, 10:34:09 am
thomas m
  • 144
« Reply #21 on: November 13, 2020, 10:34:09 am »
CTA Manufacturing,  https://www.ctatools.com/  carries a large assortment of tools for VW and others. This chart http://www.ctatools.com/index.php?route=product/download/download&did=29 has many adapters in the VOLKSWAGEN 2800 series. The injector adapter, 2800-02, is machined from a solid piece of brass. The connector nipple is not removable. I talked to a rep at the company. Their catalog is worth a glance.
The compression test kit comes with 10mm glow plug adapters. I don't know if they would exchange those for 12mm.
320,000 miles
Reply #22November 13, 2020, 12:53:31 pm
« Reply #22 on: November 13, 2020, 12:53:31 pm »
I looked at the CTA website and the linked chart before I purchased the 2800 kit.  I also looked at the various adapters that they offer.  The information is conflicting and incorrect on the chart and the website.
The 2800 kit comes with the 2800x01, 2800x02, and 2800x03 adapters.  The image on their site showing the 2800x03 adapter is definitely incorrect.  The 2800x03 is the long adapter that I show.  That adapter is not pictured anywhere on their site.  The image they use for the 2800x03 adapter on their site appears to be a second image for the 2800x09 adapter.  The chart states that the 2800x01 adapter can be used with the VW TDI's as a glow plug adapter.  That is not correct.  It is too short to fit and will not seal at the tip.  The 'correct' adapter for the VW TDI glow plugs is the 2800x08 but the long 2800x03 adapter that comes with the kit can easily be modified to match the 2800x08 and will then work correctly with the TDI glow plugs.  The 2800x02 adapter will work for ALL of the VW/Audi IDI engines (1.5, 1.6, 1.6TD, 1.7, and 1.9 AAZ/1Y).  They say that the 2800x14 will work with some of the VW engines but their info about that adapter is contradictory.  On the chart it states it is M12 x 1.25 and when looking at the details on the page for the 2800x14 they state it is M18 x 1.50.  If wanting to test via the glow plug hole on IDI engines, the only adapter that might work (based on the details of the various adapters) would be the 2800x11.  The glow plugs are all the same for all of the IDI engines so if it works for one it works for all.  I didn't receive the adapter, though, so I cannot say for sure this way or that.
I'm not sure why you would want a glow plug adapter for the IDI engines if you have a proper injector adapter for those engines.  The #1 and #2 glow plugs are quite a challenge to remove.  I'm not sure if the gauge will fit over the adapter when in place for the #1 and #2 glow plugs.  All of the glow plug adapters are missing the volume of the glow plug heating element so will skew the reading lower than it should be.  IMO, the 2800x02 adapter is better as it avoids any of those issues and already comes with the kit.  If they were to allow swapping adapters it might be nice to swap the 2800x03 for the 2800x08 in order to avoid needing the modify the 03 for use with the TDIs.
FWIW, it appears that partsplaceinc sells the gauge for $50 and the adapters for $19 each.  If only getting the gauge and one adapter, that is a fine way to go.  The appeal for me was to have a single kit that tested both the IDI and Mk3/Mk4 TDI engines.
« Last Edit: November 13, 2020, 12:55:10 pm by libbydiesel »
Reply #23November 14, 2020, 09:18:07 am
thomas m
  • 144
« Reply #23 on: November 14, 2020, 09:18:07 am »
Libbydiesel,
Do you know the designation of the quick disconnect on the CTA 2800? I've search various pneumatic manufacturers and cannot locate that configuration. I'm sure the HF gauge connector will not fit. Is there any manufacturer's identification on the CTA connector?
« Last Edit: November 14, 2020, 10:08:31 am by thomas m »
320,000 miles
Reply #24November 14, 2020, 09:46:00 am
« Reply #24 on: November 14, 2020, 09:46:00 am »
I do not see any part # on the quick connect, but it does say "HOFFMAN FLUID POWER MINATURE" (yup, they misspelled miniature).  Here's a link to the manufacturer's site:
https://www.hofmannfluidpower.com/products/steel-brass/
In looking at the fittings and measuring, I believe it is the M1-MST.  I cannot say with certainty, though, and obviously bear no responsibility if incorrect.  :)
Reply #25November 15, 2020, 10:52:24 am
thomas m
  • 144
« Reply #25 on: November 15, 2020, 10:52:24 am »
That looks pretty close. Here's the Hofmann page with the male and female connectors that look like the ones on the CTA 2800 kit.
https://www.hofmannfluidpower.com/products/quick-connect-couplings/straight-thru-coupling/
I'm suppose to hear from CTA in a couple of days and if they give me something specific I will post it here.
UPDATE: As Nov 23, I haven't heard back from CTA.
UPDATE: As of Decenber 8, 2020 I don't expect a call back.
« Last Edit: December 08, 2020, 04:50:23 pm by thomas m »
320,000 miles
Reply #26December 08, 2020, 06:39:50 pm
Re: Heat Shield Usage for Compresson Test
« Reply #26 on: December 08, 2020, 06:39:50 pm »
FWIW, a couple weeks ago I used my CTA tester to test the compression on a TDI and it worked great.  I haven't had the opportunity to test compression on an IDI engine yet and don't know when I will.
Reply #27December 08, 2020, 07:37:21 pm
  • 2932
« Reply #27 on: December 08, 2020, 07:37:21 pm »
 That's why I check compression by turning the crank by hand.
 If it tries to go backwards when compressed it's 375psi or above.
 Hard to turn but doesn't go backwards,... maybe 350.
 Not so hard to turn 325 or less and only starts in warm weather.
Reply #28December 27, 2020, 12:13:40 pm
thomas m
  • 144
« Reply #28 on: December 27, 2020, 12:13:40 pm »
Reminds me of the guy on Youtube who finds top dead center by putting a balloon on his compression hose and noticing when it start to fill up. He removes the hose from the block and then use a dowel or screwdriver to tweak it to top dead center. Then he does a leak down test.  I don't know why he doesn't want to take the valve cover off?????
320,000 miles
