1.6l IDI Crank pulley wobble
Topic: 1.6l IDI Crank pulley wobble (Read 2743 times)
July 11, 2020, 02:13:34 pm
Iamvandemon
Newbie
July 11, 2020, 02:13:34 pm »
Hello,
Have any of you seen a 1.6l with a crank pulley wobble? I have one out of a 89 that wobbles like crazy and has for some time. I just replaced the timing and the end of the crank does not show any wear or damage.
It seems that either the pulley is bent or the crank is bent. I ordered a new pulley and will mic the end of the crank before I put it on.
Any insight would be appreciated.
Van
91 Jetta 1.6l IDI
85 Golf 1.6l IDI
July 12, 2020, 08:10:48 am
Re: 1.6l IDI Crank pulley wobble
July 12, 2020, 08:10:48 am »
pulley is bent. Crank is never bent without some sort of serious visible injury. I had a precup fall in a 1.6, bent the rod into an S, windowed the block, and the crank was fine.
Round 2
July 12, 2020, 08:18:47 pm
July 12, 2020, 08:18:47 pm »
There is a bump on the sprocket that matches a hole in the pully.
July 13, 2020, 01:55:01 pm
Iamvandemon
Newbie
July 13, 2020, 01:55:01 pm »
theman53: Thanks for the reply. I hope you are right. The new pully shipped last week so hopefully I will be putting it in this weekend.
fatmobile: lol, that would be a sad mistake. Thanks for the tip though.
The tab and corresponding hole are lined up...
91 Jetta 1.6l IDI
85 Golf 1.6l IDI
July 17, 2020, 01:40:43 pm
Iamvandemon
Newbie
July 17, 2020, 01:40:43 pm »
I installed the new pully today. Spins straight as an arrow and belt no longer banjos... Thanks for the responses.
91 Jetta 1.6l IDI
85 Golf 1.6l IDI
