Author Topic: Complete Vanagon 1.6 Diesel $650  (Read 4131 times)
June 24, 2019, 11:52:00 am
markward
  • 2
« on: June 24, 2019, 11:52:00 am »
This is a running 1.6 NA diesel engine I pulled from our 82 camper when I did the TDI conversion. Odometer had 90 K when I pulled it. It has been stored in the back of my shop for all these years. The original vanagon oil pan and oil pump were lost at some point. To keep the shop out of the block I installed a pan from golf.
What you see in the pictures is what you get. No warranty expressed or implied. The buyer will need to swap their oil pan and oil pump to use this engine. You'd want to replace the timing belt as well.
Buyer is responsible for arranging shipping. I can secure to a pallet and load on a truck. This engine could get your diesel powered vanagon or other NA diesel vehicle going again, or could be a spare engine if you have the space to store it.
I'm not able to post links or pictures as a newbie. If you search the classifieds on the Samba under my same user name, you should be able to find the add with pictures. Thank you for looking. Mark
