Author Topic: Product review: Aircraft Spruce EGT Thermocouple  (Read 35649 times)
Reply #15January 27, 2007, 02:16:16 pm
speedy
  • 120
« Reply #15 on: January 27, 2007, 02:16:16 pm »
I am ready to buy an EGT gauge.  I like the sound of the 10-01478 thermocouple from Aircraft Spruce but I need to find a way to wire it to a VDO cockpit gauge in the front of my van, which is ~15ft away.
Aircraft Spruce does sell a 15ft extension cable (10-01481) but the nice lady told me that it specifically says that it will NOT work with the VDO cockpit gauge!  Wonder why?
Jake, what kind of cable did you use to connect the thermocouple to your VDO gauge?
Thanks,
-Dave
Reply #16January 28, 2007, 02:30:21 am
Hillshy
  • 103
    • http://www.hillshy.co.uk
EGT probe
« Reply #16 on: January 28, 2007, 02:30:21 am »
Quote from: Black Smokin' Diesel
Do you know if it's a UK only item and can it be bought on their american website? Do you have a part number?
firstly sorry for the late reply, really late! but better late then never i hope :lol:
i cant find the bill or the orginal bag, so i cant supply you with a part no?
http://www.airworlduk.com
he is somehow linked to airspruce,so i should think the extention cables are available via airspruce.
this is what i plan to use,before i add the extention, i'm going to get the gauge up and running, with the standard length- take some measurements. Add the extention and see how the gauge reacts.
ext cable
gauge
total length
Another thing to note, been reading old posts in relation to crimping v soldering, crimping seems to be the best way forward for a whole host of reasons.
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #17January 28, 2007, 07:08:29 am
speedy
  • 120
« Reply #17 on: January 28, 2007, 07:08:29 am »
Quote from: carrizog60
i am a bit rookie...
can someone please give the the part numbers or links to what i need for a complete setup?
i dont like very much the gauges i saw on theyr site...can i buy other and link it to theyr probes?
thank you
Google the string "K Thermocouple" and you will find lots of information.  I already did this and from reading it is my current understanding that ANY K type gauge should work with ANY K-type thermocouple.   The only question in my mind is the wiring between the gauge and the thermocouple.
-Dave
Reply #18February 07, 2007, 12:55:25 pm
big specht
  • 14
« Reply #18 on: February 07, 2007, 12:55:25 pm »
So what is best gauge to get????? I know there is alot of options but what is everybodys experances???
Reply #19February 21, 2007, 09:41:57 pm
speedy
  • 120
« Reply #19 on: February 21, 2007, 09:41:57 pm »
I got my thermocouple installed - details and pictures at the bottom of this page:
http://motorheads.net/vw/turbobus/page3.html
Thanks Jake and fatmobile for your posts on this subject which saved me lots of time, money and anguish.
I do have one question though - the probe slides in and out of the fitting easily.  How am I supposed to keep the probe from falling out, and won't it leak exhaust gasses?  Or does it just get plugged up with carbon?  Should I fasten it to the manifold with a stainless ziptie?  Bend the tip inside the manifold?  Something else?
Thanks,
-Dave
Reply #20February 21, 2007, 10:13:06 pm
« Reply #20 on: February 21, 2007, 10:13:06 pm »
Hey Speedy.... totally enjoying reading about your bus retrofit btw.
My EGT probe slides in and out as well... doesn't seem right to me since it's under pressure but thats the way it came.  I would have expected something that crimps in place given the pipe fittings.... hmmmm.
I'm planning to seal it in with muffler cement and back the cement up with a stainless steel pipe clamp... (unfortunately) I'm post-turbo so I can just clamp around the downpipe.  You might be able to use heavy wire wrapped around the initial part of the fitting where it screws into the manifold.
I can tell you're the kinda guy who likes doing the job right from your pictures so this might be a bit hokey... perhaps someone else has a more robust idea.  If it starts to leak it will sure be a pain once the manifold is bolted back on !!
Reply #21February 25, 2007, 07:07:33 pm
speedy
  • 120
« Reply #21 on: February 25, 2007, 07:07:33 pm »
Thanks Vincent.  I'm still not sure what to do about it.  A SS ziptie sounded good at first but I don't want any part of the thermocouple except the tip contacting hot surfaces.  Once it's installed I will see if I can ziptie it to something else nearby that is not hot.
-Dave
Reply #22March 08, 2007, 10:59:20 am
Jimmy Diesel Junior
  • 64
« Reply #22 on: March 08, 2007, 10:59:20 am »
Hi all. I have the same probe setup and i'm also concerned that the probe seems very loose inside the fitting and it will surely leak gasses. I'm sure that there is a simple solution but i just can't think of one  :roll:  Anyone have any ideas???
PEACE THROUGH SUPERIOR HORSE POWER
Reply #23March 08, 2007, 11:29:48 am
« Reply #23 on: March 08, 2007, 11:29:48 am »
You can allways drill the NPT fitting for a setscrew.
thats how my AutoMeter probe is held in.
Don't overtighten.
Reply #24March 08, 2007, 12:03:19 pm
« Reply #24 on: March 08, 2007, 12:03:19 pm »
And seal the gap with muffler cement...
Reply #25March 17, 2007, 08:34:56 am
stewardc
« Reply #25 on: March 17, 2007, 08:34:56 am »
Does anyone know of a nice digital readout that will work with this thermocouple?
Reply #26March 17, 2007, 08:48:44 am
« Reply #26 on: March 17, 2007, 08:48:44 am »
I don't have that thermocouple, but mine came with a compression fitting, like the kind that crimps against a copper pipe. A nut with an inside taper, a metal ferrel that is thinner towards the ends, and the fitting which also has a taper inside.  As the nut tightens, it sort of crimps the ferrel around the thermocouple. I did have to tighten it fairly tight before it started grabbing. If yours are the same type, you may just need to crank down harder.
Reply #27March 19, 2007, 05:53:29 pm
  • 656
« Reply #27 on: March 19, 2007, 05:53:29 pm »
http://www.dakotadigital.com has a few digital gauges. Not sure about them being compatible so you might want to ask them.
Reply #28March 25, 2007, 09:28:26 pm
speedy
  • 120
« Reply #28 on: March 25, 2007, 09:28:26 pm »
Quote from: jimfoo
You are a genius!  I bet that is the way it is supposed to work, but... mine does not have the washer (ferrel).  There's a slight possibility I may have overlooked it in the plastic bag it came in, if that's the case I'm screwed because I tossed the plastic bag a few weeks ago.  I suppose I will call Aircraft Spruce again and see if they can verify that it is supposed to be a compression fitting.  Maybe I can find the washer at Elliots.
Thanks,
-Dave
Reply #29March 26, 2007, 07:55:14 am
« Reply #29 on: March 26, 2007, 07:55:14 am »
hehe so much trouble from one simple part... when installing my suspension system i overlooked the box contents and had to rush around to find some nuts at canadian tire that i left at my house... finally found em! i'll get around to putting the right ones on sometime...  :lol:
