Author Topic: BOV on a TDI  (Read 12610 times)
Reply #15February 07, 2007, 04:40:42 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
BOV on a TDI
« Reply #15 on: February 07, 2007, 04:40:42 pm »
I deactivate the dump valve with a dash mounted switch wired in series to the positive side of the vacuum solenoid as 99.9% of the time I don't want particularly want to hear a dump valve going off when I change gear or back of the throttle.
When the vacuum solenoid is turned off the dump valve doesn't open, this is on a 1991 1.6 IDI SB engine running 0.8-1bar boost using a Baileys single piston dump valve.
I think unless your running substantial levels of boost the dump valve wont open without vacuum being applied.
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #16February 07, 2007, 06:01:28 pm
gigaz2
  • 626
BOV on a TDI
« Reply #16 on: February 07, 2007, 06:01:28 pm »
the dump valve is a differential device, it opens if the force exerted by the air pressure from the turbo is more than the spring force on the other side.
plus, as the spring is on the same side as the piston that controls the opening of the DV, if that spring is weak enough it doesnt need vacuum, but it works like the BOV. it makes a good swoosh, but its pointless and that can damage   the turbo by overspinning.
my opinion:  dump valves are pointless in a diesel.
Reply #17February 07, 2007, 06:11:27 pm
GTD.
  • 183
BOV on a TDI
« Reply #17 on: February 07, 2007, 06:11:27 pm »
Quote from: gigaz2
I agree, when I had drilled my airbox and fitted a free flowing air filter, I took my mate out for a spin, he asked me if that sound was the turbo spooling up, then said you should fit a dump valve, there's one in my shed.
 This was an exercise just to see if I could make up a system to actuate a dump valve from scrapyard parts, it has only been activated half a dozen times.
[Oo=w=oO]Golf GTD
Reply #18February 08, 2007, 06:04:00 am
BOV on a TDI
« Reply #18 on: February 08, 2007, 06:04:00 am »
Quote from: gigaz2
the dump valve is more safety on the motor, and i can definetly see it over spinning the turbo, but since with a bov you'd be letting off the throttle so it definetly won't over spin it
Reply #19February 09, 2007, 12:41:26 am
gigaz2
  • 626
BOV on a TDI
« Reply #19 on: February 09, 2007, 12:41:26 am »
Quote from: Trev0rbr
Quote from: gigaz2
and by BOV I mean that device that keep us from getting more than 0.7~8Bar from stock TDs.  I too agree that mouted properly its a safety device for a gasoline engine.
by the way GTD. that was serious thinking! your solution is really simple!
