17psi on ECO pump, need to control boost.
Topic: 17psi on ECO pump, need to control boost. (Read 3881 times)
June 17, 2006, 02:54:55 pm
sethyboy85
June 17, 2006, 02:54:55 pm »
I installed a garett turbo on my ECO motor before dropping it in my car, and when I got the turbo it had a hole in the waste gate can. I JB welded it and thought nothing more. Now I find out that there is supposed to be 2 nipples on the WG, I have a line running from the intake to the smaller (only nipple)
Installed a boost gauge today off of same source and am seeing 16psi by 5k in 4th gear going up a mountain. boost really just seems to rise with rpm's also being it is a ECO pump I really didn't expect to see that much boost, around 3k I have 8-10psi. the exhaust is a stock NA setup with the DP lined up close but not perfect seating on the turbo.
Next week I am going to be installing a 2.5" DP from the turbo back that should allow me to spool quicker but my concern is how to regulate the boost now... I would like to add more fuel (EGT will be installed on DP) as I never ever see any smoke and know I could use alittle more giddy up.
so to regulate boost do I have to tap the side of the WG I JB welded and put another nipple or run one of the 2 lines on the compressor housing to the existing nipple for more control? I not really sure, I am used to bleeding the line to the WG to get more boost but now this WG had 2 nipples...
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
July 02, 2006, 07:52:36 pm
sethyboy85
July 02, 2006, 07:52:36 pm »
still haven't done anything but would still appreciate input.
July 04, 2006, 11:21:31 pm
nkb
July 04, 2006, 11:21:31 pm »
ive always known wg cans with two lines are for boost and vacuum, the one furthest out from the rod being the boost side and the other for vacuum to pull the wg open for light throttle driving to keep the boost off. if you were putting boost into the vacuum port it would just hold the wg closed harder from forcing the rod to pull in the wrong direction.
you could check this by hooking a vacuum pump up to the port and see if it moves your wg open
hope this helps!!
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
July 05, 2006, 08:04:38 am
saurkraut
July 05, 2006, 08:04:38 am »
I really think your probably OK with the boost you have now. If you haven't increased your fuel delivery, and your boost is higher, then your EGT should be lower.
Someone correct me if I'm wrong.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
July 05, 2006, 11:52:35 am
July 05, 2006, 11:52:35 am »
big line is pressure from turbo, small line is indeed a bleed back to the low pressure side to help keep stuff cool.
July 05, 2006, 04:42:40 pm
nkb
July 05, 2006, 04:42:40 pm »
Quote from: libbybapa
Diesels don't make vacuum (unless there is a problem) as they are not throttled.
true but they do have vacuum pumps :wink:
2004 Jetta TDI
1986 S-10 LT1
July 05, 2006, 06:14:38 pm
sethyboy85
July 05, 2006, 06:14:38 pm »
yeah, but I am trying to increase fuel soon... the only thing holding me back is a lack of IC to go over 15psi without being more prone to blowing a headgasket as right now it IS my only car.
I did hook the line from pre turbine on compressor housing to the wg can I think it kept boost below 12psi I have to check tomorrow at the same place I got 15psi (not normal drive) will have to post after tomorrow results.
