Author Topic: Took the Rabbit to the Dyno today :)  (Read 12003 times)
Reply #30June 11, 2006, 09:07:41 pm
Staley
  • 96
    • http://www.bartuning.com
« Reply #30 on: June 11, 2006, 09:07:41 pm »
Well okay then.. I will turn it up :)
and I want that 12mm pump
GILES.. I'll send it in in a few weeks
when I can save up some more cashola.
Houston's APR Distributor
www.bartuning.com
Reply #31June 11, 2006, 09:25:32 pm
hillfolk'r
  • 1532
« Reply #31 on: June 11, 2006, 09:25:32 pm »
man you gotta get to the drags for a fun time,got any idea what that bad boy would turn??
Throttle cables ftw
Reply #32June 12, 2006, 12:40:07 am
vwmike
  • 1158
« Reply #32 on: June 12, 2006, 12:40:07 am »
Quote from: andy2
Heres some pics of the aaz and bew(pd) rods.they are better the question is how much?
http://www.msnusers.com/gtdforum/shoebox.msnw?Page=3
Edit: any they are noticeably lighter than my lightened AAZ rods
I wouldn't mind finding an aftermarket solution but that still looks like a good step in the right direction. Did you find some amazing deal on them or something? If I punch in the part number I come up with them costing about $450 each......which would be way more than a custom set of Pauter rods.
Reply #33June 12, 2006, 06:08:18 am
Staley
  • 96
« Reply #33 on: June 12, 2006, 06:08:18 am »
I was thinking about Pauter rods.. they would definately be cheaper than 450 each! yikes. I would imagine that CP could make a set of forged pistons too. then you could REALLY turn it up.. until you break a crankshaft.
www.bartuning.com
Reply #34June 12, 2006, 09:37:46 am
andy2
« Reply #34 on: June 12, 2006, 09:37:46 am »
I'm pretty sure I paid $680 cad for all 4.I'll double check,that still half the money that custom rods cost.
Reply #35June 12, 2006, 06:47:39 pm
DVST8R
  • 535
« Reply #35 on: June 12, 2006, 06:47:39 pm »
I looked into custom rods from alot of differnt manufactures, and what I decided was... next motor, I am sure malone is going custom H-beam rods for his next motor as well. The most expensive rods I could find were a custom set of Ti rods that came in at $900USD a rod  :shock: Okay I wasnt that shocked, but you can get Ti rods for about $550 each if you shop around. Every place I checked with were all in the racing business Carrillo, Eagle, Pauter ect... I think I will run forged 4340 H beam rods next time around. I found them for about $295 a rod iirc.
As for breaking a crank on a vw diesel, I think that is a new frontier I have heard of big power turbo gassers using the diesel cranks, and havn't ever heard of a failure, not say its not possible, but that would be some serious power.  :twisted:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #36June 12, 2006, 08:40:40 pm
Staley
  • 96
« Reply #36 on: June 12, 2006, 08:40:40 pm »
I went to the dyno again tonight.. with a BIG letdown.  With the main fueling turned up the
most I got was 105WHP thats 15 less!!
I turned up the boost to 27 with a VERY small change.
I have some work to do.  I ordered a new 1.9L cyl head today so that I can take it to my engine shop..
flow bench it and look into porting it.
I ordered a new connecting rod and piston also today. I called and talked with Pauter about making me some better rods...
and when I get the rod and take the measurements.. ill send that in. I want that 160WHP!!
I feel like the T3 super60 won't handle anymore than 30PSI I have been thinking about a GTseries Garrett
turbocharger like a 28 or a 28RS
With the ball bearing center section.. that has to help
any ideas?
www.bartuning.com
Reply #37June 12, 2006, 08:41:29 pm
Staley
  • 96
« Reply #37 on: June 12, 2006, 08:41:29 pm »
edit.. IT WAS VERY hot today... and I think my intercooler was REALLY getting heatsoaked. like 98deg with 89% humidity
www.bartuning.com
Reply #38June 12, 2006, 09:31:54 pm
DVST8R
  • 535
« Reply #38 on: June 12, 2006, 09:31:54 pm »
Smokin hot!!! ouch yeah its hard to reproduce numbers with that kinda heat.
As far as GT seires I think a 25R or a hybrid would work well. If you really want to go out on a limb I would try the GT30V dual axis, varible vane, ball bearing turbo. Or a Holset Hx-30, or hy-35, are all good tries for big singles.
