Author Topic: is it time for an engine rebuild?  (Read 6241 times)
May 10, 2006, 04:20:37 am
prysm
  • 41
    • http://www.fernski.com
« on: May 10, 2006, 04:20:37 am »
since I am going to replace the head gastket on my pickup I was wondering if I should go all together and replace the piston rings and valves. if I am noticing the following.
1. cannot accelarate past 45km/h on certain upward slopes. lack of power?
2. smoke in the tail pipe.
mazda B2200 2.2L R2 diesel
Reply #1May 15, 2006, 02:00:59 am
prysm
  • 41
silicon blocked coolant passages in my engine
« Reply #1 on: May 15, 2006, 02:00:59 am »
Hi
I just finished diassmbling my engine head. I found a few of water passages blocked with silicon and a bit aluminum erosion probably due the orginal owner didn't use the 50/50 mixture.
here are my questions
1. do you guys use any type of adhesive to between head and gasket and block?
2. I also went to an auto supply and ask for my engines head gasket. He asked me if I wanted the asbestos type or the steel type. what is the difference I alsways there was only the steel type
any tips would be great
thanks
,prysm
Reply #2May 15, 2006, 05:09:09 pm
zyewdall
  • 393
« Reply #2 on: May 15, 2006, 05:09:09 pm »
When I redid the head gasket on my subaru, I used spray copper gasket stuff on the head gaskets, both sides.  It's supposedly for head gaskets and exhaust gaskets.  I've never done the head gasket on the diesel so I'm not sure what to suggest though.
I think I'd stick with the steel head gaskets myself.  Again, I haven't done diesels, but on subaru's, they had a rash of head gasket failures in the late 90's, and ended up going to an improved gasket with another steel layer to keep them from blowing out (they overbored a 2.2 liter engine to 2.5 liters and it ended up being a little too weak for one piece of the head gasket).
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #3May 16, 2006, 04:58:31 am
Justin
  • 455
« Reply #3 on: May 16, 2006, 04:58:31 am »
I spray my head gaskets with the copper spray as well, it seemed to hold up well with 25 lbs of boost at 3500 rpm on the dyno, unfortuanately the bottom end of the block halfway cracked off.
later
Justin
www.archeryprostaffmi.com
Reply #4May 16, 2006, 08:37:08 am
prysm
  • 41
« Reply #4 on: May 16, 2006, 08:37:08 am »
I will see if I can find some of that copper spray.
I use head gasket shellac before.
you guys can take a look at the clogged up water ports here
http://fernanbolando.mailc.net/100_3081.jpg
http://fernanbolando.mailc.net/100_3082.jpg
http://fernanbolando.mailc.net/100_3083.jpg
http://fernanbolando.mailc.net/100_3088.jpg
http://fernanbolando.mailc.net/100_3084.jpg
By experience is it possible to save a bit of money and just clean
and reuse the valves, or I should replace the valves and spring all together?
,prysm
