Author Topic: movies, times 'n numbers?  (Read 12924 times)
Reply #15May 11, 2006, 01:19:37 pm
HP
  • 225
« Reply #15 on: May 11, 2006, 01:19:37 pm »
You're the man.  lolo
Reply #16May 11, 2006, 03:52:24 pm
hillfolk'r
  • 1532
« Reply #16 on: May 11, 2006, 03:52:24 pm »
thanks for the conversions TD,,,,ill have to keep  a conversion page nearby for this......... :wink:
heres another pic of my old truck,i took a picture of a picture again,,,cause my scanner  is packed away,but itll give you the idea........
Throttle cables ftw
Reply #17May 11, 2006, 03:56:20 pm
hillfolk'r
  • 1532
« Reply #17 on: May 11, 2006, 03:56:20 pm »
heh,dig that front plate,i lifted the front end up a chain wrapped around the bumper,using a cherry picker!! :twisted:  :shock: the big ugly
Throttle cables ftw
Reply #18May 11, 2006, 04:27:52 pm
HP
  • 225
« Reply #18 on: May 11, 2006, 04:27:52 pm »
Wacky!  :D
Reply #19May 12, 2006, 03:16:41 am
TDForNow
  • 131
« Reply #19 on: May 12, 2006, 03:16:41 am »
Hillfolk'r,
No prob, no charge, buddy!   But, I've gotta ask, how the F did you and how much did you lift that Caddy?!
Alain
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #20May 13, 2006, 09:10:07 am
hillfolk'r
  • 1532
« Reply #20 on: May 13, 2006, 09:10:07 am »
i basically set it up,so the front struts sit "topped out",like picture your car when you jack it up,and the tires are barely touching the ground,,i cut the front strut perches off,moved them up 2 inches,and rewelded them,,i also used a2 springs in front,,,,,sears trailblazer 195-70-14s tires,,,,in the back i made 3 inch longer shackles,and 3 inch blocks,it took some tweaking to get the ride height right,so it wouldnt break outer left cv joints in turns,,and it handled funny,but looked cool
Throttle cables ftw
Reply #21May 31, 2006, 01:16:08 am
2mAn
« Reply #21 on: May 31, 2006, 01:16:08 am »
Quote from: hillfolk'r
im usually a modest dude,but this tdiengine is awesome,so i have to tell every one,so they can build one too!!
you've convinced me!! im trying to sell this gas motor i just built so i can buy a tdi for my mk1 jetta!!
