Author Topic: Vacuum Gauge as Boost Gauge?  (Read 3018 times)
April 23, 2006, 10:35:41 am
Op-Ivy
  • 513
« on: April 23, 2006, 10:35:41 am »
I found a Vacuum Gauge kit that measures the psi of a vacuum line at princess auto yesterday. It goes from 0-30 psi. Would this work as a boost gauge?
Reply #1April 23, 2006, 10:47:46 am
Mathdiesel
  • 6
« Reply #1 on: April 23, 2006, 10:47:46 am »
It wouldn't work, and also it most likely be in inches of mercury rather then psi, since vacuum is relative to atmospheric pressure and atmospheric pressure is only 14.7 psi.
Reply #2April 23, 2006, 05:05:46 pm
mpg
  • 49
« Reply #2 on: April 23, 2006, 05:05:46 pm »
princess auto has gauges for compressors and such, that go to 30 psi, and some that go higher. the one i got is for a regulator for an acetylene cutting torch or something, goes to 50psi, and cost me $7.
'90 Jetta AAZ T3 lifted
'81 Caddy project
'84 GLi 1.9 16V
'03 GLi 24V 6spd
Reply #3April 23, 2006, 05:32:00 pm
TDForNow
  • 131
« Reply #3 on: April 23, 2006, 05:32:00 pm »
At least in std (us) format, if it reads in "PSI" (Pounds per Square Inch) it measures pressure relative to atmospheric, if it reads in "IN-HG" (inches of mercury) it measures vacuum relative to atmospheric
'85 Quantum 1.6TD
'04 Passat 2.0 8vTDI
Reply #4April 24, 2006, 04:49:53 am
Darkness_is_spreading
  • 288
They have vaccum and Boost Gauge combos at princess
« Reply #4 on: April 24, 2006, 04:49:53 am »
I picked up one but it only runs to 20 lbs of boost, but mine is running maybe 27 lbs of boost, and I think I damaged the gauge, because at idle It tells me I'm running 2 lbs of boost  :shock: .
I'm going to try the reguator gauges, I have a 0 - 30 pressure gauge prob for oxy and celtaline.
83 Jetta 1.9 T (Project Darkness)
88 Jetta 1.6 NA (Dead/Crushed)
92 Jetta 1.6 T (Sleepin)
96 Golf 1.9 T (Parts Car + Mexican Rust Bucket)
Reply #5April 24, 2006, 06:28:13 am
shwartzbewithyou
« Reply #5 on: April 24, 2006, 06:28:13 am »
I think if you look, the princess auto gauge that you are looking at has boost on one side and vacuum on the other.  I think it is a boost gauge.
If you want a cheap gauge they have a pressure gauge in the hydraulics section for $4.99 that measures up to 30 PSI.  It's for air filters but the only issue is it doesn't have a light in it because it's not an auto gauge.
That doesn't matter to me because my dash lights don't work anyways but it may to you.
Reply #6April 25, 2006, 04:58:35 pm
Mark(The Miser)UK
  • 1557
Boost/ vac gauge
« Reply #6 on: April 25, 2006, 04:58:35 pm »
I use a boost gauge with the ombined vac. This monitors state of air filter when it's not showing boost ie at idle.
Mark-The-Miser-UK
