Author Topic: Source for proportioning valve seals  (Read 55526 times)
March 07, 2019, 03:51:50 pm
« on: March 07, 2019, 03:51:50 pm »
This is a wild shot in the dark I know.  But has anyone ever replaced those small washer like seals in the valve body?  I recently purchased a used valve body in hopes that the seals would still be OK but the internals were pretty full of sediment of some sort.  The one spring was compressed and stuck on to the valvestem and that misformed the seal to where it will not stay on anymore.
Looked all over for this part, not sure if it is/was ever made as these valves are listed as non repairable.  I think I finally met something that was but only due to lack of parts now.
Any one ever find new seals?  Not the O rings, the other one that is in there.
Reply #1March 07, 2019, 08:56:35 pm
  • 2931
Re: Source for proportioning valve seals
« Reply #1 on: March 07, 2019, 08:56:35 pm »
Hi my name is Craig and I hoard MK1 proportioning valves.
 How much did you pay for a used one?
Reply #2March 08, 2019, 09:22:08 am
« Reply #2 on: March 08, 2019, 09:22:08 am »
I got mine from an old buddy and he didn't really charge me much.  But having the valve as a spare is only good if the little tiny washer like seals are good.  That is the part/parts I need now.  The body and red pistons are in perfect shape.
If you really need a price do a PM and I will let you know.  But again, buddy price.
Not really market price, or Ebay price.
Reply #3March 08, 2019, 07:52:43 pm
  • 2931
« Reply #3 on: March 08, 2019, 07:52:43 pm »
Right, and I can't really take one apart and tell if the seals are good enough to work.
 I have to put them in another valve and test it.
 I'm not really sure how they work or why the seals have little bumps.
 Other wise they kind of look like wheel cylinder seals.
Reply #4March 08, 2019, 08:25:24 pm
« Reply #4 on: March 08, 2019, 08:25:24 pm »
I think the little bumps are so some fluid can pass but when you really stomp on them, like panic time babe, the smooth flared edge catches the extra pressure and puts a crimp on the pressure to the rear brakes.  That keeps them from locking up.  Or at least tries to.  Having all that mass moving forward and the rears locked tends to push you in a circle.  That means more pressure up front and hopefully you can control the steering and keep it all in a straight line.
I hit the hardware store and found that the only type of seal that would come close to meeting the diameters and width was an O ring that was 1/4 ID, 7/32 OD, and a 3/32 inch width or thickness of the doughnut.  I am not sure this is going to do the job as it stops all flow through the body of the unit when I screw down the nut on the spring.  That is why I think the bumps as you call them allow some passage of air when the unit is assembled.  I was going to hook it up to the MC and see if anything comes out the bottom just for giggles.  Who knows I may stumble on a source or possible fix for these things at last.
I was told when I was shopping around that the reason these valves have no available parts is due to the liability issue for a rebuilder.  It is a safety item on the vehicle and should one rebuild it they become liable for its service.  Well you can't hardly see down that cylinder to see if it was scored up or not and you can't hone it out either.  So they just expected people to go buy another.  We can't do that anymore for our 40 year old cars now can we.
I will report back on the use of the o rings in place of the washer like seals with the bumps.  I am not holding my breath that they will work even a little bit.  But for less than 2 bucks I figured I could try it over doing nothing.
Reply #5March 11, 2019, 08:00:28 pm
« Reply #5 on: March 11, 2019, 08:00:28 pm »
Well some of you are probably mumble I knew that, but the experiment with the O rings was a fail.  They do not allow passage of any amount of fluid.  So I will have to eyeball the four seals I have, find the best two and try them to see if they make the valve do right.  Back in a few days perhaps with a report.
Reply #6March 14, 2019, 06:44:14 am
« Reply #6 on: March 14, 2019, 06:44:14 am »
...they just expected people to go buy another.  We can't do that anymore for our 40 year old cars now can we...
FWIW, PP says they still stock the MK1 & MK3 proportioning valves...
https://www.partsplaceinc.com/vw-mk1-brake-proportioning-valve-15346.html
« Last Edit: March 14, 2019, 06:45:59 am by TylerDurden »
Reply #7March 14, 2019, 08:11:01 pm
« Reply #7 on: March 14, 2019, 08:11:01 pm »
Last time I looked at PP the picture was of the older version that is in back of the axle.  I have the newer 81 style that is down on the front drivers fender.  Might need to call and get a better description if my rebuild using the best of the four seals I have available to me doesn't work well.
At least I got it all clean inside and the little red pistons are not sticking on the o rings anymore.  Hope that it does OK.
Reply #8March 15, 2019, 07:00:57 pm
  • 2931
« Reply #8 on: March 15, 2019, 07:00:57 pm »
 There's no picture in that link but it says it's for the early ones.
 You can get those for cheaper than $200 lots of places, last time I looked.
Reply #9March 15, 2019, 07:29:02 pm
« Reply #9 on: March 15, 2019, 07:29:02 pm »
I actually had a used one sent to me from a guy that has lots of cars and a few trucks.  Cost me all of 22 bucks shipping included.  It just came with the caveat that it might not be any better than the one I already had.  And sure enough the piston was jammed up and the spring compressed down all the way.  And those are pretty solid springs.
I cleaned it up and was able to use one of the seals in it as it was better than one I had.  Seems that when the piston sticks on the spring, or is it the other way around?  The seal gets smashed into the piston from the backside and deforms it.  Makes it about a mm bigger and thus it becomes useless to keep fluid from going either way.
Going to get some time tomorrow I hope to check for performance on the rebuilt component.
Reply #10March 16, 2019, 05:41:49 pm
« Reply #10 on: March 16, 2019, 05:41:49 pm »
Found the time and the sunshine today to reinstall the valve.  I had hard lines by passing it for awhile as a test.
After the reinstall and the required bleeding of all four lines I have better but not the best brakes.  How do I compare?  I have my 81 Rabbit with the same system and it stops like no problem.  Pedal is high and tight, does not bleed down.
The one on the Caddy is not so high, and slowly melts under pressure.  So thinking the new MC I put in is not holding up.  May have to talk to the Autozone folks for a return.
Dang I thought I was done here.
Reply #11July 10, 2019, 11:22:53 am
BarrySon
« Reply #11 on: July 10, 2019, 11:22:53 am »
Looking for a source for the typical plain grade stock for a Model 81 -- nothing fancy like a curved buttplate.
Anyone have a current source?
Reply #12February 29, 2020, 06:56:53 am
Chuck1978
  • 77
« Reply #12 on: February 29, 2020, 06:56:53 am »
I went through lots of hassles with these old proportioning valves.... They are I believe a combination proportioning valve & also rear drum brake residual check valve (the red anodised plunger shafts with the springs & funny looking bumpy washer on the end)?
On my wife's 82 pickup, I always had trouble bleeding & getting fluid to the rear brakes, after a hose failure, & later a rusted line replacement.
Then I was out of commission for 6 months at the end of winter 2019, post-knee-surgery, & my 82 pickup's brakes had all gone to crap after sitting all winter& to early summer.
I replaced every part in the system over a few attempts, booster, master cylinder TWICE, wheel cylinders, hoses, calipers, probably close to a gallon of brake fluid just bleeding over & over.
Finally the 2nd time I tore apart the proportioning valve for a cleaning/reassembly, & then bled it extensively from the valve, then I finally got some better braking back...
Careful as the lines are tough to get to when installed, and very tough to get threads started properly on. Make sure your flare nuts are in god shape, or else fab up new hard lines from Nickel-Copper bulk tubing rolls, + stainless steel fittings. The NiCu lines will allow much easier alignment of starting the threads.
Also, I was primarily bleeding them from cracking open the hex cap o-ring seals after initial bleeding from the lines.  DO NOT remove these on the vehicle, only loosen. You WILL NOT have much luck fighting the springs on reinstall when reaching way down there thru everything.
The red anodised plunger pistons get all kinds of gunk buildup between them & the springs, & get seized onto the o-ring/plastic seal/guide fitting in the steel hex cap, & render them non-functional.
BEWARE...when these things become freed up, they will launch like a cannon
« Last Edit: February 29, 2020, 07:07:51 am by Chuck1978 »
Reply #13February 29, 2020, 07:12:23 am
Chuck1978
  • 77
« Reply #13 on: February 29, 2020, 07:12:23 am »
The centering piston at the top is the safety valve feature to cut off one circuit of brakes in the event of a catastrophic leak.
The problematic red plunger assembly is the rear drum residual check valve assembly and also proportioning valve to limit a percentage of fluid traveling to the rear brakes. These are built into the master cylinder on most other vehicle applications. Drums require a few psi of pressure constantly on their lines to achieve quick brake actuation. This is the purpose these springs & plungers serve.
« Last Edit: March 01, 2020, 06:17:11 am by Chuck1978 »
Reply #14February 29, 2020, 08:12:35 am
Chuck1978
  • 77
« Reply #14 on: February 29, 2020, 08:12:35 am »
I have a bunch of photos of these dismantled, but both this forum and vwvortex do not post up here to host photos. There are Photobucket photos on this, but you get a blurred watermarks version at least viewing on mobile, I think desktop site they might still work on Photobucket
https://forums.vwvortex.com/showthread.php?4294532-OEM-proportioning-valve
« Last Edit: December 23, 2023, 06:08:48 pm by ORCoaster »
