Author Topic: 1.6TD injector spray pattern  (Read 2894 times)
December 14, 2018, 08:05:31 pm
Huc
  • 34
« on: December 14, 2018, 08:05:31 pm »
https://imgur.com/a/vEGYITB
The spray pattern differs a bit between my injectors. They both pop around 2000psi. The Bentley says "check that the injector sprays in an even, compact cone pattern...". How compact/narrow should it be? I'm worried that an incorrect spray pattern can damage the precups, but the Bentley isn't very specific on what the spray pattern should look like.
Reply #1December 14, 2018, 08:25:11 pm
Re: 1.6TD injector spray pattern
« Reply #1 on: December 14, 2018, 08:25:11 pm »
Those are both fine provided they both pop cleanly at a similar pressure and don't pee streams below the pop pressure.
Reply #2December 14, 2018, 11:26:53 pm
  • 2926
« Reply #2 on: December 14, 2018, 11:26:53 pm »
"and don't pee streams below the pop pressure."
I bought some new bosch injector inserts,..
 and they pissed worse just before breaking pressure than some of the old injectors I have.
They were made in brazil ,.. I'll buy india made nozzles next time.
Reply #3December 15, 2018, 01:17:39 am
Huc
  • 34
« Reply #3 on: December 15, 2018, 01:17:39 am »
Thank you very much for your help
Reply #4December 15, 2018, 02:16:32 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: December 15, 2018, 02:16:32 am »
Sigh....... ::)
It is just miserable having to wade through so much dross these days, parts wise.
Badge engineering didn't die with British Leyland unfortunately.
