External oil cooler hose size
Topic: External oil cooler hose size (Read 3553 times)
September 30, 2018, 03:44:36 pm
slow and ratty
Newbie
September 30, 2018, 03:44:36 pm »
I have a Vanagon 1983 with 1.6D na engine. Adding external oil cooler. I got all fittings from local hydraulic shop. I thought I was supposed to get 5/8 ID hose, but doing more reading it seems like 1/2" ID is better. I already bought 5/8". Is that too big? Will my oil pressure suffer? Mounting cooler in front of transmission and using thermostatic sandwich plate. New to this. Any feedback greatly appreciated.
October 05, 2018, 05:19:15 pm
slow and ratty
Newbie
Re: External oil cooler hose size
October 05, 2018, 05:19:15 pm »
I'll try the 5/8 and report back on any issues.
October 05, 2018, 08:10:28 pm
Moderator
4553
October 05, 2018, 08:10:28 pm »
5/8ths sounds to large for my tastes. That sounds more like water cooling size. I used a sandwich between the flange and filter for an external Frantz cooler and I think the inside diameter of that hose was closer to 1/4 inch. Once it got to the external filter it had a sleeve in the inlet that dropped the diameter down to 1/16 I believe. b
But that particular filter is not designed to have a huge flow going into it. You are also looking for flow to cool the oil so I would venture a guess that you are a bit big on diameter. Maybe drop a couple of 8ths and go with a 3/8th if you find you lack pressure.
The oil pump only can produce a given volume depending on RPM. Flow is a measure of a combination of pressure and diameter of hose. A given volume will be at a higher pressure with a smaller diameter hose.
October 13, 2018, 05:01:58 pm
slow and ratty
Newbie
October 13, 2018, 05:01:58 pm »
Thanks a million. I have already purchased 5/8 to 3/8 hose reducers. The fitting for the oil cooler are 5/8 so that is what I was going with but that could be for a Jaguar or something. Peace
October 16, 2018, 04:07:31 pm
ToddA1
October 16, 2018, 04:07:31 pm »
I’ve run 5/8 in the past, with no issues.
-Todd
November 22, 2018, 07:32:58 am
slow and ratty
Newbie
November 22, 2018, 07:32:58 am »
Good to know thanks.
