Engine Specific Info and Questions > TDI Engine -General Info
98 AHU problems... Won't rev
Smoker:
--- Quote from: burn_your_money on February 10, 2018, 05:59:42 pm ---Is it MK3s that have an issue with the wiring for the timing advance solenoid being rubbed off by the corrugated wire wrap?
--- End quote ---
Hmmmm... I haven't heard of this. But they sounds plausible.
Sent from my SM-G955U using Tapatalk
EJslava:
98 civic dx 5spd d16y7stock wont rev passed 3000 rpm after a while it just turns off anybody know what it could be??
smutts:
Are you sure the fuel filter is not gunked up? Pipes from the tank not kinked?
A good sized air leak into the fuel lines might also cause white smoke.
Have a look at the fuel pickup in the tank if you suspect the previous owner used vegetable oil as fuel?
Good luck.
ORCoaster:
EJslava, Your vehicle, 98 civic dx 5spd d16y7stock, is not a diesel that I know of. Why would you even post to this forum?
Because you are a bot I suspect.
Navigation
[0] Message Index
[*] Previous page
Go to full version
