Author Topic: unknown problem  (Read 11617 times)
Reply #15April 15, 2006, 06:50:53 pm
stewardc
unknown problem
« Reply #15 on: April 15, 2006, 06:50:53 pm »
The last ones I bought at the dealer were about $.50 each but I have replaced it with a piece of wire to get me there....always buy 2 and keep 1 in the ashtray.
See the problem when you replace a part and then focus on that part???
Always look for the obvious first.
Glad to be able to help.
Reply #16April 15, 2006, 06:54:02 pm
zagarus
  • 619
unknown problem
« Reply #16 on: April 15, 2006, 06:54:02 pm »
you have no idea how happy you made me!  see thats what this forum is for, cause you diesel brains know what to check for first.  My mechanic buddy, i guess from working on gassers so much assumed white smoke to be burning coolant.  once again thank you so very much!  haha, cancel the selling of my car  :lol:
Reply #17April 15, 2006, 07:00:29 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
unknown problem
« Reply #17 on: April 15, 2006, 07:00:29 pm »
Yeah, that one burned be before as well. Also, if you're driving along and it goes dead, you can also look at the connector on the injector. Mine had a habit of backing itself off just enough (combined with the amount of oil on the engine) that it would exhibit similar problems.
Leave it overnight. If it behaves the same after checking those two things, it may be your fuel filter hasn't filled up with fuel and the injector is sucking air. Last time I replaced mine, I didn't put any diesel in it, but I believe that the best practice is to do so.
You'll make 'er.
Reply #18April 15, 2006, 07:03:44 pm
zagarus
  • 619
unknown problem
« Reply #18 on: April 15, 2006, 07:03:44 pm »
:D  :D
Reply #19April 15, 2006, 11:51:56 pm
LeeG
  • 401
unknown problem
« Reply #19 on: April 15, 2006, 11:51:56 pm »
the proper replacements are cheap, I got like 4 for a buck and still got some change back
'97 Passat TDI
Reply #20April 16, 2006, 09:13:08 am
hillfolk'r
  • 1532
unknown problem
« Reply #20 on: April 16, 2006, 09:13:08 am »
Quote from: "LeeG"
,,yea get the right fuse,,,,ihave fount they usually dont "blow",,they rot apart,,usually where one of the screws holds it down,and its not really visible tillyou remove it,then it falls todust in your hand,,,,in a pinch,,ive taken like 3 strands of wire,and twisted them together,for a temporary fuse to get me out of the boonies :wink:
Throttle cables ftw
Reply #21April 16, 2006, 10:15:47 pm
zagarus
  • 619
unknown problem
« Reply #21 on: April 16, 2006, 10:15:47 pm »
are they specific fuses or can i get them at walmart of canadian tire?
Reply #22April 16, 2006, 10:20:12 pm
unknown problem
« Reply #22 on: April 16, 2006, 10:20:12 pm »
I'm pretty sure they are specific.  Because the glow system can draw a lot of power for a short period of time its probably best to grab the best fuse money can buy (or a few cheaper ones... especially in winter)
Reply #23April 16, 2006, 11:00:17 pm
zagarus
  • 619
unknown problem
« Reply #23 on: April 16, 2006, 11:00:17 pm »
no one would happen to know the amp rating would they?
Reply #24April 17, 2006, 03:28:51 am
stewardc
unknown problem
« Reply #24 on: April 17, 2006, 03:28:51 am »
They are only available from the dealer, or a VW parts place because of the mounting. They are 50 amps, I believe.
Reply #25April 17, 2006, 09:17:32 am
fspGTD
  • 1529
unknown problem
« Reply #25 on: April 17, 2006, 09:17:32 am »
Moved to troubleshooting
Jake Russell
Reply #26April 17, 2006, 09:40:16 am
stewardc
unknown problem
« Reply #26 on: April 17, 2006, 09:40:16 am »
Quote from: "fspGTD"
It was already IN troubleshooting.  :oops:
Reply #27April 17, 2006, 11:41:42 am
zagarus
  • 619
unknown problem
« Reply #27 on: April 17, 2006, 11:41:42 am »
thats what i thought :?
Reply #28April 17, 2006, 02:04:32 pm
fspGTD
  • 1529
unknown problem
« Reply #28 on: April 17, 2006, 02:04:32 pm »
I'm glad that you guys agree this thread belongs in troubleshooting.  IIRC before I moved it, it was miscategorized in the IDI Engine (power enhancement) section, but I could be remembering that wrong. :oops:
Jake Russell
Reply #29April 17, 2006, 02:15:27 pm
stewardc
unknown problem
« Reply #29 on: April 17, 2006, 02:15:27 pm »
Aha, the heady aroma of diesel soot has finally effected your brain cells  :wink:
