Author Topic: wont work right/less fuel after pump assembly  (Read 13924 times)
Reply #15December 23, 2016, 12:25:00 pm
Re: wont hold idle after pump assembly
« Reply #15 on: December 23, 2016, 12:25:00 pm »
The shim is chosen by measuring a clearance in the pump and then selecting the correct thickness.
There's no shim that goes with a particular head or a particular case, one is selected based on the results of your measurements with your particular combination of parts and their respective stacked tolerances.
Reply #16December 24, 2016, 02:39:39 am
carrizog60
  • 978
« Reply #16 on: December 24, 2016, 02:39:39 am »
ok,this time i now for sure that the shim is in place.
timed the engine,the pump at 0.95mm and started.
and still the same.
-fuel screw is all in and i cant get the smoke levels that had before(not that i want smoke but no smoke is no fuel)
-the travel on the accelerator lever seems to be less than before(i needed to make almost half travel on accelerator to get it going so it is right that now i cant get the lever to go to the stop screw.its wrong on the normal working of the pump but makes sense)
-when starting the engine the rpm will be lower and starts to rise slowly to the selected idle rpm,before it would start and stay at given rpm.
-seems to have more rpm drop when fan starts,or any other power consumer.
the engine noise is normal,pump rotates well by hand and i feel lost.
Portugal
Reply #17December 24, 2016, 04:06:51 am
carrizog60
  • 978
Re: wont work right/less fuel after pump assembly
« Reply #17 on: December 24, 2016, 04:06:51 am »
try to start it again now after cooling it down and would start right away but will die right away if i dont give it some gas.after a bit it would stay at idle...
any thoughts?
the problem is that the car is needed,i need to take my kid to school so i take the other car and my wife is going to work with is sv650,wich is a very fun bike but not on a 30km trip at 7a.m. in winter...
Portugal
Reply #18December 24, 2016, 04:51:02 pm
« Reply #18 on: December 24, 2016, 04:51:02 pm »
Just checking... have you confirmed the location of the cam?  Cam lobes for #1 are UP and not #4, right?
Reply #19December 24, 2016, 08:51:13 pm
« Reply #19 on: December 24, 2016, 08:51:13 pm »
i just replace the o´rings on the advance mechanism and on the pump head.
So it was stated at the beginning of the thread.  I wonder if that alignment is off when the timing is being done.  That might bear looking into.
Reply #20December 25, 2016, 03:19:50 am
carrizog60
  • 978
« Reply #20 on: December 25, 2016, 03:19:50 am »
yes timing is right
alignment on timing advance mechanism or in the pump head?
i align the plunger notch with the slot in the pump nose for the pulley,any other alignment is needed?
is ther any thing that could move before the camplate?should i take it apart further ?
Portugal
Reply #21December 25, 2016, 02:27:14 pm
carrizog60
  • 978
« Reply #21 on: December 25, 2016, 02:27:14 pm »
ok,found it.
for some reason i might had removed the control collar and installed it on the other side. :P
Portugal
Reply #22December 25, 2016, 06:32:44 pm
« Reply #22 on: December 25, 2016, 06:32:44 pm »
Good work figuring it out and thanks for posting the result.
Reply #23December 25, 2016, 08:36:32 pm
« Reply #23 on: December 25, 2016, 08:36:32 pm »
I have to look twice every time I disassemble a pump for which direction that collar needs to be on the shaft.  Glad you finally have resolution.  And Yes thanks for the results follow up.
Reply #24December 25, 2016, 11:26:17 pm
carrizog60
  • 978
« Reply #24 on: December 25, 2016, 11:26:17 pm »
i always like to post the results,hope that saves some headaches if someone is on the same position.
today will take it to work and see if everything is ok.
Portugal
