Author Topic: 1Z TDI swap 85 jetta (jenny)  (Read 4417 times)
September 14, 2016, 09:38:31 pm
big dipper
  • 4
« on: September 14, 2016, 09:38:31 pm »
hi dudes! im busten out a swap project and im looking for a little help, been searching the forums and learning alot but there are some problems ive run into that have turned into a bit of a hurdle. i have the motor and trans sitting on the MK2 subframe on the stock mounts (which im cool with) but the 1Z has a serpentine belt and a v belt with the v belt on the outside running the water pump and power steering pump. my car does not have power steering, but it does need a water pump. so one of the problems im having is the pulley on the crank shaft rubs the wrinkle zone and i cant get the motor to move over any further to the drivers side  ??? has anyone been here that could give me some advise?
Reply #1September 19, 2016, 06:41:47 am
  • 5104
Re: 1Z TDI swap 85 jetta (jenny)
« Reply #1 on: September 19, 2016, 06:41:47 am »
run the mk2 accessories?
Reply #2September 22, 2016, 08:34:18 pm
big dipper
  • 4
« Reply #2 on: September 22, 2016, 08:34:18 pm »
that alternator though
Reply #3October 11, 2016, 08:47:21 pm
« Reply #3 on: October 11, 2016, 08:47:21 pm »
Do you have AC? If not there's a belt configuration that uses the serpentine to drive the water pump and alternator. No need for a v-belt at all if you go that way.
