Author Topic: 1.6TD - sludge all over rear engine bay!  (Read 9065 times)
Reply #15July 06, 2016, 12:48:30 pm
oblique
  • 317
    Diesel while you can.
Re: 1.6TD - sludge all over rear engine bay!
« Reply #15 on: July 06, 2016, 12:48:30 pm »
I am also equipped with torque wrench.
Like not the kind from Harbor Freight. Or the kind that comes attached to the allen wrench with OEM VW roof racks.
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #16July 06, 2016, 01:10:03 pm
« Reply #16 on: July 06, 2016, 01:10:03 pm »
I take it the picture is one of the later types.
Reply #17July 06, 2016, 02:26:43 pm
oblique
  • 317
« Reply #17 on: July 06, 2016, 02:26:43 pm »
Yea that ones from a mark iv. I'm sure theyve made radical advancements in accuracy for these types of torque wrenches since mk1 days.
Here a better shot of one:
« Last Edit: July 06, 2016, 02:47:08 pm by oblique »
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #18July 18, 2016, 09:08:49 am
oblique
  • 317
« Reply #18 on: July 18, 2016, 09:08:49 am »
whats with the crappy new boots? I spent the money to get a quality product and while the boot is smaller and slightly easier to install, its much harder and not nearly as supple as the old one.
I had no trouble removing the axle nuts but whats with the torquing procedure?+ Torque to 148ft-lb, undo 180deg, torque to 37ft-lb and the turn another 60deg? wtf.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #19July 18, 2016, 04:02:45 pm
« Reply #19 on: July 18, 2016, 04:02:45 pm »
It looks to be plastic rather than rubber.  That might be a good thing due to how much more quickly rubber degrades due to environmental contaminants now.
What do you find confusing about the torque spec?
Reply #20July 18, 2016, 05:39:20 pm
air-cooled or diesel
« Reply #20 on: July 18, 2016, 05:39:20 pm »
i think 1 of the points your confused on is the 37ftlbs, you cannot have car down on its own weight and roll the car without some kind of axle end. you ruin the wheel bearing like right now, i do believe all MK1s MK2 &MK3s had this. so snug axle nut good, or use an impact, then put car on the ground, and i use a pipe and get some turn on it. what is it about 200.
Reply #21July 18, 2016, 07:53:49 pm
« Reply #21 on: July 18, 2016, 07:53:49 pm »
Mk1 Bentley says to loosely install the axle nut, lower the car to the ground, torque axle nut to 173 ft-lbs.  They make a special note that the car MUST be on the ground for torquing the axle nut.
Mk2 has a says similar - "WARNING - Torque the axle shaft nut only while the car is on the ground.  The torque required to do this could topple the car off a lift or jack stands".  The Mk2 torque spec is 195 ft-lbs.
I don't know where Oblique came up with the multi-step torque procedure.
Reply #22July 19, 2016, 02:56:35 am
« Reply #22 on: July 19, 2016, 02:56:35 am »
^im sure this is before it was easy or normal to have an impact, when on stands i hit with impact.
Reply #23July 19, 2016, 08:27:42 am
« Reply #23 on: July 19, 2016, 08:27:42 am »
I'm quite sure impacts were in very common use by 1985 when the mk2 was released.  I can even remember way back that far...  Attempting to torque a fastener to proper torque with an impact is not very smart.
Reply #24August 06, 2016, 07:34:51 pm
« Reply #24 on: August 06, 2016, 07:34:51 pm »
for the older 'model' or years you may be correct, yet im too lazy to repeat my self. ^ this came first. and if your so-called torquing with an impact; i hit it, what was the problem with that?
« Last Edit: August 12, 2016, 04:02:43 pm by air-cooled or diesel »
Reply #25August 16, 2016, 11:19:13 am
« Reply #25 on: August 16, 2016, 11:19:13 am »
Thread purged of non technical content. Keep it on topic.
Reply #26August 16, 2016, 08:40:43 pm
« Reply #26 on: August 16, 2016, 08:40:43 pm »
thanks Admin.
