And then this fell out...
Topic: And then this fell out... (Read 6052 times)
October 12, 2015, 05:06:46 pm
mapper
Newbie
October 12, 2015, 05:06:46 pm »
Hi All,
This is my first post and I want to kick off by saying what a great resource I've found this site. I really appreciate the expertise and experience that's captured here.
My task, I'm rebuilding a 1.6 td JM engine. If successful, my plan it to put it in my jetta and pull the aaz from that for my van.
This is my first rebuild and I've hit a snag I want to fix before I bolting up the head, etc. During the tear down early in the year this guy dropped out the engine as I rotated it on the stand. Anyone recognize it? Can you tell me where it belongs?
Thanks,
Steve
mmh.. can't get image to display. h t t p s://flic.kr/p/yKFngE
Last Edit: October 12, 2015, 06:01:20 pm by mapper
October 12, 2015, 05:45:02 pm
Re: And then this fell out...
October 12, 2015, 05:45:02 pm »
try BB code
19
by
sja_young
, on Flickr
October 12, 2015, 06:04:34 pm
mapper
Newbie
October 12, 2015, 06:04:34 pm »
sorted... thanks!
October 12, 2015, 06:28:17 pm
October 12, 2015, 06:28:17 pm »
That's pretty weird right there. It certainly isn't a factory VW part. I don't think VW used a single nylock anywhere on the engine itself....
October 12, 2015, 06:51:18 pm
October 12, 2015, 06:51:18 pm »
I've pulled quite a few 1.6TD engines down to their most basic bits and have never seen that part.
October 12, 2015, 07:53:02 pm
rallydiesel
October 12, 2015, 07:53:02 pm »
Is that some kind of expansion plug? Definitely not a vw part as was mentioned already. I'd check the external oil passage bores and make sure the proper plugs are in place.
1991 Jetta TD - sold
2001 Golf TDI - Son's
October 12, 2015, 09:06:13 pm
mapper
Newbie
October 12, 2015, 09:06:13 pm »
Thanks guys. I took it apart. It's not clear in the photo, but there's fine mesh on the nut and a spring a small bearing inside. Seems like its a tappet. I had thought it was associated with the intermediate shaft, but couldn't see how. I'll set it aside.
Cheers,
Steve
October 13, 2015, 07:50:37 am
Rabbit79
Burns, Oregon,USA
October 13, 2015, 07:50:37 am »
Hmmm.... spring and ball bearing inside sounds like a check valve. Perhaps some sort of over-pressure relief.
Last Edit: October 13, 2015, 07:54:39 am by Rabbit79
Current: 1979 Rabbit 4dr
1984 F-250
1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
70 Bug
October 14, 2015, 08:07:02 am
Renxx
Newbie
October 14, 2015, 08:07:02 am »
Pressure control valve from power steering pump.. Look for spring too!
October 14, 2015, 08:16:48 am
October 14, 2015, 08:16:48 am »
Nice. How'd that get in the engine?
October 14, 2015, 05:06:37 pm
Moderator
4553
October 14, 2015, 05:06:37 pm »
Makes you wonder how well his power steering is working doesn't it?
Reply #11
October 14, 2015, 10:56:50 pm
mapper
Newbie
Reply #11 on:
October 14, 2015, 10:56:50 pm »
Quote from: Renxx on October 14, 2015, 08:07:02 am
Impressive bit of ID'ing. Thanks Renxx
I pulled the rocker cover and oil pan before stripping down the engine... wanted to check the cam and crank before getting too much time into it. My guess is the spring and Murphy's law did the rest when I disconnected the power steering hose.
Thanks again
