Author Topic: 1.6 NA idle keeps dropping  (Read 2621 times)
August 08, 2015, 01:35:51 pm
larkout
  • 6
« on: August 08, 2015, 01:35:51 pm »
Every couple of months I have to turn in the idle adjustment screw on my mk1 Rabbit to stop it from shaking... the motor mounts have all been recently replaced so I think that the idle speed really is slowly dropping.  Does anybody have experience with a similar situation or an idea of why this might be?
Reply #1August 08, 2015, 05:34:38 pm
Rabbit79
  • 197
    Burns, Oregon,USA
Re: 1.6 NA idle keeps dropping
« Reply #1 on: August 08, 2015, 05:34:38 pm »
I did have a similar situation quite a few years back, ended up being IP bracket bolts. As I recall one had broken and one had fallen out, leaving the IP bracket only being held on by 2 bolts. Led to rough idling and surging while driving. Can't say that's your problem but it's easy enough to check.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
70 Bug
Reply #2August 08, 2015, 08:52:20 pm
  • 4553
« Reply #2 on: August 08, 2015, 08:52:20 pm »
I had the nut that locks it in place loosen up and then the stub would follow shortly there after.  Could not seem to get a good position on the nut when I had other WVO hoses in the way.
