Author Topic: What happens if you put a gasser filter on a 1.6 na?  (Read 3416 times)
August 05, 2015, 08:11:22 am
rs899
  • 647
« on: August 05, 2015, 08:11:22 am »
...just once. Does it blow up? I just have one leftover mahle oc47 that I want to start a rebuilt engine on and run for 20 minutes before I change it and the oil. Looking in it, there looks to be a restrictive valve an inch down. I dunno....
Reply #1August 05, 2015, 06:59:11 pm
Re: What happens if you put a gasser filter on a 1.6 na?
« Reply #1 on: August 05, 2015, 06:59:11 pm »
It'll PROBABLY be ok for that short of a use at this time of year.  Cold weather operation is a much bigger issue as 15w40 on a cold day can get up to 150 PSI at startup pretty easily.  But for a 20 minute run on a new build I don't see it being an issue whatsoever.
Reply #2August 05, 2015, 08:02:53 pm
Dakotakid
  • 1240
« Reply #2 on: August 05, 2015, 08:02:53 pm »
Seems like the gas o-ring is a little smaller....can't remember. It may spray oil past the top due to the difference (if there is one). The clean-up will give you something to do.
I think the gas oiling systems develop the identical pressures. I have never ruptured a gas filter tin.....yet. And, I have run a lot of 15-40 in gas rigs over the years.
Reply #3August 06, 2015, 02:14:26 pm
rs899
  • 647
« Reply #3 on: August 06, 2015, 02:14:26 pm »
Yes, seems to me they all use the same oil pump. I am using the gasser filter flange (this is a cabriolet conversion) as it has the car pressure and oil temp sensors. I need to double check the seat before I make a mess.
Reply #4August 06, 2015, 04:06:50 pm
« Reply #4 on: August 06, 2015, 04:06:50 pm »
From what I have read the gas oil filters have a lower burst and bypass rating.
Reply #5August 09, 2015, 11:52:18 am
« Reply #5 on: August 09, 2015, 11:52:18 am »
I wouldn't be too concerned about the burst rating, odds are the starting oil pressure on one of these still isn't high enough to cause rupture, unless something is woefully defective, but with a lower bypass rating it may simply just send the oil right past the filter without filtration.
Reply #6August 09, 2015, 06:50:16 pm
« Reply #6 on: August 09, 2015, 06:50:16 pm »
Proper filter $5
engine rebuild $1000+
Seems simple to me.
Reply #7August 10, 2015, 07:33:42 am
rs899
  • 647
« Reply #7 on: August 10, 2015, 07:33:42 am »
The only way it would ruin my engine would be if it grenades and takes me with it.  My head will be over it.  I have the right filter, just want to use this one up, if I can do it safely.
