Author Topic: Need direction on my 95 Turbo Diesel Golf  (Read 4686 times)
April 04, 2006, 04:46:55 pm
paladin
  • 6
« on: April 04, 2006, 04:46:55 pm »
Just bought this 95 TD golf 1.9, need to know what clutch kit to put in it and where to get it. Great car has only 60k miles on it. Would also like to know oil filter, air filter, oil weight ect.  Thanks so much!!
sean
1995 Golf Turbo Diesel 1.9
Reply #1April 04, 2006, 05:01:13 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #1 on: April 04, 2006, 05:01:13 pm »
I've had very good results from Euro-drive clutches' (burlington) parts. Specifically, lightened 210mm flywheel with 2L 16v pressure plate and a KEVLAR clutch disc. Bulletproof. Needs a gentle 1000km break-in period though. Just put this setup (02A version) in Chris-pl's passat. 10 lbs off  the flywheel. Throttle response is markedly improved.
Reply #2April 04, 2006, 09:03:56 pm
Cheesetoast
  • 285
« Reply #2 on: April 04, 2006, 09:03:56 pm »
amsoil 5-40 european spec in my 93 1.9td, doesn't burn a drop, use a mahle filter too
Reply #3April 05, 2006, 05:46:00 am
paladin
  • 6
Hey Dr Diesel
« Reply #3 on: April 05, 2006, 05:46:00 am »
I am looking more for an inexpensive/reasonably durable clutch kit. I will probably sell the car in the near future. Do you know where I can purchase the appropriate clutch kit for the 1.9 TD? Does anyone have a part number for the Oil filter or know if it is the same as any other VW filters in the US. Always a fun time locating VW parts for an engine that never came to the US.  Thanks All
sean
Reply #4April 12, 2006, 01:03:52 pm
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #4 on: April 12, 2006, 01:03:52 pm »
Moved to troubleshooting section
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
