No start after 1.6TD rebuild, FIRST START 6/13!!
Topic: No start after 1.6TD rebuild, FIRST START 6/13!! (Read 8090 times)
June 01, 2015, 10:19:17 am
Rock3tman
prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
June 01, 2015, 10:19:17 am »
Fresh rebuild on carefully rebuilt 1.6TD, can't get to start/or even fire...Now it tries to run away and I have to use the shutoff solenoid.
1) there's fuel to injectors when lines cracked and cranking, pump set at .97mm. old bendix pump used as lift pump (can be heard before cranking) there are no bubbles in line from filter. pump stored with ATF during rebuild that's been replaced by diesel by now
2)
pimped glowplugs working correctly
Each glowplug was fused for 15A; all blown...replaced with 30A (glowplug leads are 8ga. stranded) and immediate start!!
3) actual starting attempts with the battery fully charged-spins a little faster than on the video
4) I'm getting a little blue smoke that smells like unburned fuel after a ~20 sec cranking attempt
Looking for suggestions on what I've missed or could be the problem: see attached video (sorry for shaking/phone was taped to hood prop rod)
http://s1264.photobucket.com/user/Rock3tman/media/VID_20150520_123753.mp4.html?sort=3&o=0
thanks, Bob
Last Edit: June 13, 2015, 11:09:08 am by Rock3tman
June 01, 2015, 11:40:03 am
golfmk1tdr
Re: No start after 1.6TD rebuild
June 01, 2015, 11:40:03 am »
Is your pump timed right, who set it to 0.97 ? Did you check you have read correct marking on flywheel?
You stored it ATF,did you make sure all of it is drained now?
Is return line free/not clogged?
Are metal fuel lines conected correctly?
Take it easy so you don't destroy battery/starter, don't rev for more than 15 seconds or when it gets slow.
Avoid Starter sprey, it will not help you on rebiuld engine.
Stay calm, you will sort it, I almost lost it few times when starting mine for first time,
it was sucking air by fuel line because tube I used was bit big, but IT DIDN'T LEAK
But I could get it to start a bit then it died immidiately, yours doesn't even try so I think you have something else (still good idea to check all fuel lines).
I am sure there will be better responses, just braintorming possile isuess at you.
Also very interesting turbo/IC position and VTN wichcraft, let us know how that works out.
Good luck
1.6+holset MK1 Golf TDR /TurboDieselRacing
(no GTD because GT is grand tourismo and there is nothing grand and touristic in my stripped out lowered beast)
June 01, 2015, 07:59:58 pm
Rock3tman
June 01, 2015, 07:59:58 pm »
I set it to 0.97 and rechecked a few times. I used the diamond-shaped mark on the flywheel that's located between the two squarish marks of 12BTDC and 20ATDC.
If anyone around Seattle has a piezo sensor and timing light adapter I'd really like to try that process.
ATF is out of pump, metal lines are connected correctly, but I haven't checked the "OUT" bolt (will clean with brake cleaner)
June 01, 2015, 08:53:24 pm
June 01, 2015, 08:53:24 pm »
Make sure you're actually injecting on #1 when #1 is at TDC. You may be timed 180° out. Does your IP pulley have two lock holes (many do) and did you use a pump lock to set it up?
You can crack the #1 injector nut and then bar the engine over, you'll see some fuel swell up at the injector union when the pump is actually at #1. Then you can make sure the cam and crank are aligned.
Last Edit: June 01, 2015, 08:58:59 pm by vanbcguy
June 01, 2015, 09:34:34 pm
air-cooled or diesel
June 01, 2015, 09:34:34 pm »
the bluish smoke you can disregard for now, not important, if any one thing it tells you have oil in the cylinders, thats 1 good thing, as long as you didnt accidentally time cam/pump 180 out, id start with glow plugs, sure you have juice at plugs? you may have set it up right, doesnt mean ,somehow, its not working right, possible all 4 gps are not working. the only other thing it can be is compression, after troubleshooting glowplugs, perhaps compression test? id also check intake, that theres no blockage, possible you had a rag in intake, you assembled and missed blockage.
the timing diamond must be right (tdc) or youd be mixing valves timing motor, as the mark i have is a notch. take another look and make sure in that area theres not another mark.
June 01, 2015, 11:11:02 pm
Rock3tman
June 01, 2015, 11:11:02 pm »
Thanks Vanbcguy - yes, my IP pulley has two locking holes. Can I pull the nut on the pump and check the orientation of the shaft keyway? Which way should it point if the sprocket is on correctly?
June 02, 2015, 06:32:53 am
June 02, 2015, 06:32:53 am »
There is a mark on the inside edge of the sprocket which should align with the top centerline of the pump when the pump pin is in the correct hole and the cam is correctly set for #1 TDC.
June 02, 2015, 08:15:09 am
June 02, 2015, 08:15:09 am »
If you cannot find what Libbydiesel is telling you then you can just take the nut off and look at which direction the keyway is pointing. IIRC it should be pointing at the 10-11 o'clock position for TDC on #1
Round 2
June 02, 2015, 09:48:44 am
June 02, 2015, 09:48:44 am »
i think van had the best idea so far, cracking inj line #1, and seeing if its timed to cyl#1, keep in mind if you have to key on and turn over the engine, technically its live; other wise inj#1 will squirt at #4. libbs idea i know, but i have a notch on the outside of pump pulley, 1 tooth is marked, on the tin theres a mark you can line in up with, about 11o'clock on tin. thats where the pump pin fits in so that will be #1.
June 11, 2015, 12:19:26 am
Rock3tman
June 11, 2015, 12:19:26 am »
Today I pulled the IP sprocket nut and washer: keyway is at 10-11 o'clock position when flywheel is at TDC, and the sprocket mark, pump mark, and pump bracket marks all essentially line up. Pulled the OUT banjo bolt and small orifice and hollow bolt end looked fine. It was wet there, so fuel is reaching there.
Glow plugs felt cool after two cycles before start attempts, so I plan to jump them directly from battery tomorrow. They glowed red-hot on 12volts and didn't show any tip erosion.
Still smells of raw fuel..and not a hint of firing.
June 11, 2015, 06:31:24 am
June 11, 2015, 06:31:24 am »
Some times these take a long time to get the air out.
Round 2
Reply #11
June 11, 2015, 02:35:24 pm
Dakotakid
Reply #11 on:
June 11, 2015, 02:35:24 pm »
I watched the video:
....why oh why oh why oh why are you not pulling the throttle all the way open when rolling over the engine?
This is not a computer controlled system....put the wood to it.
In the past with initial start-ups on new engines, I have used a small amount of brake clean or carb cleaner (not nearly anything like ether) or a bit of wd-40 to aid in the initial fire. In the event of having no one else to assist you: run a detachable wire directly to the glow plugs from the battery. Prop open the throttle pivot with a folded piece of paper or something, use a screw driver to jump across on the starter. Just make sure the trans is in neutral prior to this excursion.
Turn your key on, walk over and ignite the glow plugs, have the pump opened up, roll the engine over with your right hand and give a squirt with your left. the turbo intake tract makes it a little more complicated than an n/a....but, I am willing to bet you are more resourceful than you are giving yourself credit. Just be careful to not ground and blow your glow plug fuse, etc. Put out your cigarette....wear goggles.....know where you fingers are..........yada yada. AND, of course, DON'T drop ANYTHING into the cam belt.....best to have the cover in place.
There....I am burned-out on disclaimers. I had my attorney from Boy, Dewey, Porkum, and Howe look this over and got his approval.
Now, the "closet intellectuals" will line up to dismiss the wd-40....however, I am not talking about inserting the entire can in the intake tract. Just a rather small amount to give it that initial roll-over. For me, it worked like a charm...a safe charm.
I am not in the soon-to-come camp which suggests pull starting, either.
The hyd. lifters are probably not pumped up yet. If solid lifters, did you meticulously set them after assembly. etc.?
Last Edit: June 11, 2015, 02:51:44 pm by Dakotakid
Reply #12
June 12, 2015, 10:49:32 am
Rock3tman
Reply #12 on:
June 12, 2015, 10:49:32 am »
<<Dakotakid>>
Thanks for the tips. During my usual ~15-20 sec. start attempts, sometimes I've held the throttle to the floor for, then closed for ~ 5 sec., then open again. Also even tried cycling the cold start advance handle. The engine cranking sounds a little different when cold start pulled vs. not pulled and otherwise left pulled out was the only change.
After a battery charge top-up, on the next start attempt I'll try:
key-to-on,
manual glow plug harness from battery to plugs,
holding throttle open at the pump, a little WD-40 or brake cleaner into the intake, and
jump across starter. Car is on jackstands currently, and will be in neutral as well.
I'm also still looking for someone who has a diesel pulse adapter (piezo) in Seattle area to check the pump timing by another process. anyone?
Thanks, Rock3tman.
Reply #13
June 12, 2015, 10:14:19 pm
Dakotakid
Reply #13 on:
June 12, 2015, 10:14:19 pm »
This afternoon, I re-installed a stock pump which had been sitting in dry storage for a little over 6 months. I have no pusher pump on this particular car. Made sure the pump was filled. Rolled it over twice for a bit. Kept the throttle wide open he entire time. On the third attempt I gave it a small amount of carb cleaner (roughly 2 second shot out of new can) which helped to "quicken" the pace of roll over. On the 4th attempt it fired lightly. On the fifth I had lift-off. The pump moved the air out while burping and then, vroom.
Granted, the lines had not been sitting for long uncapped. I was NOT interested in burning up this starter. I don't like to let pumps sit longer than 6 months. Therefore, having spares is a hassle. But, they are paid for.
Last Edit: June 12, 2015, 10:16:54 pm by Dakotakid
Reply #14
June 13, 2015, 12:26:14 pm
Rock3tman
Re: No start after 1.6TD rebuild, FIRST START 6/13!!
Reply #14 on:
June 13, 2015, 12:26:14 pm »
What would be the potential causes of runaway upon first start after rebuild?
The valve cover breather is disconnected, the IP sat with ATF in it for three years. The pump was never opened and none of the external adjustments have been tampered with (collar is still on fuel screw, etc.). The throttle return to idle seems OK.
