General Information > Smoke Tales
T 25 1.6 td slow hill climb
<< < (2/2)
Sansu:
--- Quote from: TylerDurden on May 21, 2015, 07:41:30 am ---I'd tee into the boost line to the injection pump with a long line to a boost gauge in the cabin. See if the turbo makes boost on a steep hill.
Low boost will likely result in sooty smoke. ~10psig is normal.
And as noted above, heavy loading or lugging the engine can result in some sooty smoke.
--- End quote ---
right and possible
JameBUYv:
I have seen that crazy looking purple/yellow car at the Rob Roy Hill climb a couple of times.
seamaster301:
Did you ever find out what was causing the power issue?
ernst60:
Hello, it is probably fuel because the black smoke means that the fuel needs to be adjusted and it should be good to set the pressure right, I had the same problem, I set the injectors to the same pressure and now it is good, but in another car
Navigation
[0] Message Index
[*] Previous page
Go to full version
