Author Topic: Best type of MBC for K-14 turbo/AAZ engine  (Read 4083 times)
May 19, 2015, 11:50:33 am
AAZTristar
« on: May 19, 2015, 11:50:33 am »
I want to add a manual boost controller to my AAZ converted Vanagon Tristar truck. I bought a nice ball and spring type boost controller, but while reading some other posts came across a reference that the older KKK K-14 type turbos should use a bleed type MBC. (something about the waste gate needing a flow of air for cooling vs being totally blocked by ball/spring?)
Is this correct? And what would happen if I did use the ball/spring type MBC?
I currently have a Giles super pump, external oil cooler setup, the BOV is blocked, and have a boost gauge that shows the truck running at 11-12 psi max. I would like to bring it up to 15psi for now until I build an air/water intercooler setup.
Also, the truck still has the JX intake manifold from the original engine. Will I be able to use a AAZ intake and still use the JX turbo and exhaust setup?
Any help on these questions will be greatly appreciated!
« Last Edit: May 19, 2015, 12:30:17 pm by AAZTristar »
Reply #1May 19, 2015, 11:44:52 pm
Re: Best type of MBC for K-14 turbo/AAZ engine
« Reply #1 on: May 19, 2015, 11:44:52 pm »
On my ball and spring controller,I put a dent in the  ball seat for the cooling air to leak by.  It worked as intended on the first try.
Reply #2May 20, 2015, 07:03:32 am
jmaddocks
  • 75
« Reply #2 on: May 20, 2015, 07:03:32 am »
The bleed isn't for cooling air - it simply enables air to escape the WG diaphragm.  Without it, air gets trapped in the diaphragm even as boost decreases, causing your WG to stay open.   ;)
I ran a Dawes MBC for a while on one of my cars.  It has the bleed valve.  www.3barracing.com
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #3May 20, 2015, 07:22:53 am
« Reply #3 on: May 20, 2015, 07:22:53 am »
The K24 does actually have a bleed built in to the wastegate can which is supposed to be for cooling. The K24 also has the wastegate actuator mounted directly to the turbo hot side. Theoretically using a ball and spring style controller with a K24 isn't the best idea, but I ran mine like that for a long time.
The K14 however has its wastegate actuator remotely mounted I believe. That makes the whole thing moot, no cooling is required nor does the actuator have a bleed built in.
Reply #4May 20, 2015, 08:19:36 am
« Reply #4 on: May 20, 2015, 08:19:36 am »
The VW K14s have the same wastegate actuator design as the K24.
Reply #5May 20, 2015, 09:47:39 am
« Reply #5 on: May 20, 2015, 09:47:39 am »
Gotcha.  So then yep, it likely has the same bleed setup.
Reply #6May 20, 2015, 12:48:33 pm
« Reply #6 on: May 20, 2015, 12:48:33 pm »
My VAG T3 on  the Volvo has the  same "KKK" design.  Boost control was erratic and spiky till I 'engineered'  the  leak into it.
Reply #7May 21, 2015, 06:00:17 am
jmaddocks
  • 75
« Reply #7 on: May 21, 2015, 06:00:17 am »
Hmm...I'd never heard about the cooling air before.  Learn something new every day I guess.   :)
Reply #8May 21, 2015, 09:40:46 pm
AAZTristar
« Reply #8 on: May 21, 2015, 09:40:46 pm »
Been camping. Thanks for the replies.
So…., to create a bleed path through a ball/spring type MBC I just make an indent in the face of the ball seat? How large?
Any help on the intake question?
« Last Edit: May 21, 2015, 09:45:26 pm by AAZTristar »
Reply #9May 22, 2015, 02:34:12 am
« Reply #9 on: May 22, 2015, 02:34:12 am »
didnt take much, maybe like the  lead of a mechanical pencil.
Reply #10May 22, 2015, 04:52:04 am
  • 5104
« Reply #10 on: May 22, 2015, 04:52:04 am »
u can also drill a tiny hole, theres lots of info for it online.
