Author Topic: Non A/C bracket Inject Pump mount  (Read 3158 times)
April 22, 2015, 08:40:56 am
jlpst94
  • 72
« on: April 22, 2015, 08:40:56 am »
91 Jetta TD.  Swapped in a Non A/C bracket and the bracket that bolts to the IP bracket  will not fit right.   It's in the way of the timing belt cover.   Non A/C bracket is more than likely from an MK1
Is the IP tin different for Non A/C cars ?  Are the MK1 brackets different than MK2?
I don't want to cut or change anything.  I have a trailer full of MK1/MK2 parts so if the tin is different or bracket I'd like to use the correct parts if someon can lead me in the right direction.
Anyone.........Thanks !
Reply #1April 22, 2015, 08:46:30 am
Re: Non A/C bracket Inject Pump mount
« Reply #1 on: April 22, 2015, 08:46:30 am »
I don't think the mk2 had a "tin" all the ones I have seen are plastic.
Reply #2April 22, 2015, 08:24:18 pm
  • 2931
« Reply #2 on: April 22, 2015, 08:24:18 pm »
You might have a 1.5 IP bracket.
What kind of alternator bracket did you try to stick to it?
 You didn't have a MK2 bracket?
Reply #3April 23, 2015, 02:08:20 pm
jlpst94
  • 72
« Reply #3 on: April 23, 2015, 02:08:20 pm »
The cover is plastic but the engine side is metal.  The bracket might be from a 1.5, but it's cast and I was assuming the 1.5 was stamped steel.
I had an mk2 a/c setup but I had a few non a/c brackets laying around that are mk1.
 The bracket is fine, it's the piece that mounts to the IP tin that is causing problems
Reply #4April 23, 2015, 02:20:44 pm
jlpst94
  • 72
« Reply #4 on: April 23, 2015, 02:20:44 pm »
Just read a post on a different forum that said you can't bolt the bracket to the IP with these non a/c brackets.   Hmmm, I really wanted to delete the a/c belt setup, but I'm kinda Leary about not mounting the IP to this bracket.
I would post an image but I don't see an option to do that
Reply #5April 23, 2015, 03:12:38 pm
jlpst94
  • 72
« Reply #5 on: April 23, 2015, 03:12:38 pm »
Now I'm seeing that the MK2 bracket can be used for a/c or non a/c.
Anyone know what I need to change to get rid of the a/c compressor and run 1 belt ?    I'm assuming there are different pulleys for the crank, water pump, and power steering.
Reply #6April 23, 2015, 04:09:03 pm
« Reply #6 on: April 23, 2015, 04:09:03 pm »
The alternator itself has different mounting bosses and yes, there's a different pulley. When I did mine my alternator was pretty old so I just got a new one. I went on to Partsbase and figured out the brackets and fasteners then ordered them from a dealership.
Reply #7April 27, 2015, 10:01:50 am
  • 2931
« Reply #7 on: April 27, 2015, 10:01:50 am »
There is a MK2 non-AC alternator bracket upgrade post in the FAQs.
