Author Topic: low compression on one cylinder  (Read 4652 times)
April 08, 2015, 03:54:33 am
dave friday
  • 122
« on: April 08, 2015, 03:54:33 am »
Hi all,as above..i have three readings of 370psi and one of 260psi!
I have checked that the valves are sealing by using an air line,no hiss from the inlet or exhaust but plenty from the valve cover/crankcase breather.
I think ive got a cracked on that piston.
Any thoughts/guesses?
Ta.
1992 1600 td syncro camper
Reply #1April 08, 2015, 04:18:31 am
air-cooled or diesel
Re: low compression on one cylinder
« Reply #1 on: April 08, 2015, 04:18:31 am »
i had a couple of years ago shopped around and found pistons, meyhle, for around $130 a set, and other parts by shopping around, i say a re-head too, and other stuff.
Reply #2April 08, 2015, 04:44:25 am
  • 5104
« Reply #2 on: April 08, 2015, 04:44:25 am »
not necessarily a cracked piston, and id highly doubt that anyway.  could be a cracked ring or that cylinder just wore more for some reason.  you won't know what u have till u pull the head, if the bores look ok, measure them, if theyre with in spec u can just hone and rering.
Reply #3April 08, 2015, 05:20:44 am
manehfr
  • 27
    GOLF MK2 1.9 M-TDI
« Reply #3 on: April 08, 2015, 05:20:44 am »
my guess... im almost sure its the piston rings...
GOLF MK2 1.9 M-TDI
Reply #4April 08, 2015, 05:41:01 am
dave friday
  • 122
« Reply #4 on: April 08, 2015, 05:41:01 am »
Thanks both,I missed out "top ring" .I replaced the low cylinders piston+rings and re-rung the other three pistons 9000miles ago,I honed the cylinders but there was/is a bit of a ridge at the top of the bores!
This was done as a temporary measure!..the cylinders are bored to 77.51mm [maxed]
Reply #5June 06, 2015, 04:36:02 pm
dave friday
  • 122
« Reply #5 on: June 06, 2015, 04:36:02 pm »
Hi all, the rings on no 3 are ok but the head and gasket are not,all 4 pre-cups have cracks also there is a small crack between the pre-cup and the inlet valve seat on no 2 ...
what to do?
Is the head scrap,do I bolt it back together and hope for the best?
Reply #6June 07, 2015, 06:33:46 am
Dakotakid
  • 1240
« Reply #6 on: June 07, 2015, 06:33:46 am »
This would be interesting to see.
Do you have a digital camera for a clear picture?
This sounds terminal.
Reply #7June 07, 2015, 08:44:41 am
dave friday
  • 122
« Reply #7 on: June 07, 2015, 08:44:41 am »
How do I attach the pictures?
Reply #8June 07, 2015, 06:47:28 pm
Dakotakid
  • 1240
« Reply #8 on: June 07, 2015, 06:47:28 pm »
Reply #9June 07, 2015, 09:09:05 pm
« Reply #9 on: June 07, 2015, 09:09:05 pm »
The head is scrap.
Reply #10June 08, 2015, 01:45:26 am
dave friday
  • 122
« Reply #10 on: June 08, 2015, 01:45:26 am »
Thanks both...
Reply #11June 12, 2015, 12:55:22 am
dave friday
  • 122
« Reply #11 on: June 12, 2015, 12:55:22 am »
Hi all,i've been to two "machine shops" for advice on how to buy a new head, one said to reuse the head but that it might fail in the future ,the next shop said that the cracks weren't a problem but I should to have it pressure tested and surface ground!
I bought a "SB"engine so will start a new thread for that.
Reply #12June 12, 2015, 08:30:25 am
« Reply #12 on: June 12, 2015, 08:30:25 am »
Cracks around the prechamber area on the head make it very likely that it'll drop a prechamber in to the cylinder in the future with disastrous results. Doesn't sound like either shop is familiar with these style of engines.
Reply #13June 12, 2015, 12:54:10 pm
dave friday
  • 122
« Reply #13 on: June 12, 2015, 12:54:10 pm »
Thanks,i did have a go at knocking number 3 pre-cup out..i gave up![AMC Spanish head ]
