mTDI Mechanical TDI Conversions
M-tdi
Topic: M-tdi (Read 5481 times)
March 11, 2015, 09:36:10 am
Meilleur
Newbie
M-tdi
March 11, 2015, 09:36:10 am »
Bonjours
Je recherche un diy pour monter une pump m-tdi sur un alh .
Merci
March 11, 2015, 10:53:44 am
Re: M-tdi
March 11, 2015, 10:53:44 am »
Sorry, my french is not good enough to write...
Land Rover 300TDI pump is a direct bolt on for the ALH. Use the ALH pump sprocket and hub, and the ALH delivery valves. That's it! Nothing to it.
March 11, 2015, 12:43:14 pm
Meilleur
Newbie
Re: M-tdi
March 11, 2015, 12:43:14 pm »
ANGLAIS
Thank you for your answer. It is not a recipe with vw pump aaz ??
March 11, 2015, 03:44:54 pm
Re: M-tdi
March 11, 2015, 03:44:54 pm »
There is a way to use a combination of TDI, AAZ and 1.6 pump parts to make an M-TDI pump, but the Land Rover pump is a much simpler solution as it does not require any modification. They are somewhat commonly available on eBay in both new and used form:
http://www.ebay.ca/itm/LAND-ROVER-DISCOVERY-300-TDI-DIESEL-INJECTION-PUMP-ERR4046-WARRANTY-BOSCH-/291381853690?pt=LH_DefaultDomain_3&hash=item43d7b63dfa&vxp=mtr
March 11, 2015, 05:06:38 pm
Re: M-tdi
March 11, 2015, 05:06:38 pm »
Or you may want to check this!!
http://www.vwdiesel.net/forum/index.php/topic,35507.0/topicseen.html
March 11, 2015, 05:18:54 pm
Meilleur
Newbie
Re: M-tdi
March 11, 2015, 05:18:54 pm »
Thx vanbcguy ☺
M-tdi
