Author Topic: AAZ O2A/O2J Suggestions  (Read 4453 times)
March 07, 2015, 06:25:54 pm
Big Daddy Roth
  • 298
« on: March 07, 2015, 06:25:54 pm »
I have a 95 B4 AAZ. Fresh engine, holset he200wg, giles pump, blah blah blah.....
The CHA trans is geared way too low.
I'm wondering what others are using for a cable shift trans.
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1March 07, 2015, 06:35:25 pm
Big Daddy Roth
  • 298
Re: AAZ O2A/O2J Suggestions
« Reply #1 on: March 07, 2015, 06:35:25 pm »
I have a CTN trans but I'm thinking that's way too tall.
1993 TD B3 Sedan
Reply #2March 09, 2015, 06:03:25 pm
« Reply #2 on: March 09, 2015, 06:03:25 pm »
I <3 my CTN... Works perfectly for me.
Reply #3March 10, 2015, 09:33:40 am
Big Daddy Roth
  • 298
« Reply #3 on: March 10, 2015, 09:33:40 am »
I put a VR6 R&P into my CHA trans. I'm finding that cruising around at 50 - 60 is a high reving 3rd or bogged down 4th. I also don't shift into 5th till 120.
I'm thinking a Rado g60 trans is a happy medium with the 3.6 R&P.
1993 TD B3 Sedan
Reply #4March 10, 2015, 09:40:55 am
Big Daddy Roth
  • 298
« Reply #4 on: March 10, 2015, 09:40:55 am »
An ALH trans is essentially what I have now. Aside from the .717 5th.
1993 TD B3 Sedan
Reply #5March 10, 2015, 10:34:35 am
Big Daddy Roth
  • 298
« Reply #5 on: March 10, 2015, 10:34:35 am »
MTDI or TD? The idi doesn't Rev as high as the TDI head does.
1993 TD B3 Sedan
Reply #6March 10, 2015, 11:09:55 am
« Reply #6 on: March 10, 2015, 11:09:55 am »
what?
Reply #7March 10, 2015, 01:39:21 pm
« Reply #7 on: March 10, 2015, 01:39:21 pm »
M-TDI but the rev range would make an IDI quite happy.
The CTN has the lowest numerical gearing of any transmission in the family. Very diesel friendly and great for the highway. Not the best for drag racing.
Reply #8March 10, 2015, 06:30:19 pm
Big Daddy Roth
  • 298
« Reply #8 on: March 10, 2015, 06:30:19 pm »
So you cruise 50 - 60 kph in 3rd at what revs?
1993 TD B3 Sedan
Reply #9March 10, 2015, 06:35:09 pm
Big Daddy Roth
  • 298
« Reply #9 on: March 10, 2015, 06:35:09 pm »
I wonder what the tall 5th would be like with that tall R&P? Lol
1993 TD B3 Sedan
Reply #10March 11, 2015, 08:31:13 am
« Reply #10 on: March 11, 2015, 08:31:13 am »
Low to mid 2ks around 50-60 in 3rd with 195/55R15 wheels...
Reply #11March 12, 2015, 08:48:23 pm
starrd
  • 128
« Reply #11 on: March 12, 2015, 08:48:23 pm »
This is the gearing chart- ignore the 6th gear - that is an option.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #12March 13, 2015, 05:54:28 am
« Reply #12 on: March 13, 2015, 05:54:28 am »
I like that chart starrd why don't you start another thread and I will sticky it or put it somewhere.
Reply #13March 13, 2015, 09:18:50 am
« Reply #13 on: March 13, 2015, 09:18:50 am »
Giles ran a CTN on his AAZ with a k14 and also with a T3. It did fine. I drive closer to 100 on the highways and was usually in 4th when I borrowed his car but Giles made better use of 5th.
Reply #14May 21, 2015, 09:27:21 am
Big Daddy Roth
  • 298
« Reply #14 on: May 21, 2015, 09:27:21 am »
No, seriously. Its not a big change, but will it make the 4-5 shift too wide?
1993 TD B3 Sedan
