Author Topic: install my mtdi pump 0460424138 but what should I set the timing to?  (Read 6382 times)
January 04, 2015, 12:31:11 pm
countach
  • 2
the Engine is a 1Z and the nozzles are set to 210 bar but what should i set the timing to??
Reply #1January 04, 2015, 02:01:58 pm
Re: install my mtdi pump 0460424138 but what should I set the timing to?
« Reply #1 on: January 04, 2015, 02:01:58 pm »
What's the pump from?
Reply #2January 04, 2015, 02:44:54 pm
countach
  • 2
« Reply #2 on: January 04, 2015, 02:44:54 pm »
the pump is from vw lt28 lt 46 2.8tdi mechanical pump
Reply #3January 08, 2015, 07:49:12 am
rodpaslow
  • 670
« Reply #3 on: January 08, 2015, 07:49:12 am »
My pump is a vw pump with land rover internals - it's a bit of a hybrid because wanted to just be able to bolt it on.  With mine running currently stock 1Z/AHU injectors I have it set as far advanced as possible (pump slots at max toward engine) at 1.40 using the dial gauge.  This should equate to about 12° BTC.  I starts beautifully even at -30°C now that we have winter.
I would start at 1.3 or so (if you have dial gauge).   The Mtdi pump needs to be much more advanced than the old IDI engines.  My $.02
Reply #4January 08, 2015, 09:27:42 am
« Reply #4 on: January 08, 2015, 09:27:42 am »
I'm running a Rover pump too... Mine is at about 1.40 give or take, I used the dial gauge to get it in the neighbourhood and then used my pulse adapter and timing light to find 12° BTDC.
I know I've seen mention of the LT pump around quite a bit but I'm not sure if anyone on here specifically has run one.  Lots of Rover / Cummins pumps though.  The cam plate / head are different in the LT pump so the Rover numbers aren't going to mean all that much.
Reply #5January 11, 2015, 03:23:15 pm
rbremiller
  • 69
« Reply #5 on: January 11, 2015, 03:23:15 pm »
I've run the same LT 2.8 pump you have for 2 years. .90mm is a good starting point for timing this pump.
'91 180k Audi 80Q mTDI DD AHU, K14, LT pump,
http://www.motorgeek.com/viewtopic.php?t=45645
'99 Jetta TDI 204k '02 engine, RC3+E, 11mm IP, .216, Racepipe, 2.5''SS exhaust, PD Lift pump,  Boostvalve, PanzerPlate, boost gauge, MAF delete.
'89 Audi 80Q ...waiting
'85 BMW R80
Reply #6January 11, 2015, 08:24:12 pm
« Reply #6 on: January 11, 2015, 08:24:12 pm »
Some say 12 degrees at  idling speed  is a good start.
Reply #7January 11, 2015, 10:03:13 pm
« Reply #7 on: January 11, 2015, 10:03:13 pm »
12 degrees works great for me. But you need a light to find that. With any luck one day someone with an LT pump and someone with a pulse adapter will be in the same place at the same time...
