Author Topic: How does my 1.6TD idle sound to the experts? / Stalling  (Read 11694 times)
Reply #15November 16, 2014, 08:32:30 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
Re: How does my 1.6TD idle sound to the experts? / Stalling
« Reply #15 on: November 16, 2014, 08:32:30 pm »
I'll see if i can get someone to hold the camera while i crank it. No wife or kids here.
Reply #16November 16, 2014, 08:35:09 pm
« Reply #16 on: November 16, 2014, 08:35:09 pm »
Just get good sound. The way it sounds running I would think you are alright, but sound on the internet can be deceiving.
Reply #17November 16, 2014, 08:50:19 pm
TimpanogosSlim
  • 590
« Reply #17 on: November 16, 2014, 08:50:19 pm »
I'l see what i can do tomorrow after work
Reply #18November 17, 2014, 09:33:27 am
TimpanogosSlim
  • 590
« Reply #18 on: November 17, 2014, 09:33:27 am »
High temp today will be 30f. You want this with or without block heater?
.:Sent by pneumatic tubes
Reply #19November 17, 2014, 05:30:29 pm
TimpanogosSlim
  • 590
« Reply #19 on: November 17, 2014, 05:30:29 pm »
it actually got up to 45f today.
Here's an audio-only recording from outside the car with the hood open.
http://ej0rge.asuscomm.com/R_MIC_141117-060040.mp3
A timing issue wouldn't surprise me. Unfortunately I have a day job now, get home after dusk, have no covered workspace, and it's gonna be wet this weekend. But if there's a reasonable break in the weather I can give timing another try.
oh, and yes there is air in the tank return, and in the leak line nearest the injector with the cap. perhaps the cap has failed - I'll get a brass tee and do that arrangement
« Last Edit: November 17, 2014, 05:58:02 pm by TimpanogosSlim »
Reply #20November 17, 2014, 09:29:37 pm
EcoTX
  • 113
« Reply #20 on: November 17, 2014, 09:29:37 pm »
All I can say after listening to that is WOWOW
Poor turbo diesel (and starter) !! :'( :'(
If this were a normal 1.6TD I'd say you have timing WAY off or some dead cylinders...
Since you have both a franken engine and a franken pump, not sure what advice to give, you're in very experimental territory and kind of on your own here.
About the only thing absolute you can rule out are compression numbers, do you know the compression numbers?
I mean you literally have an engine and pump that is a mish-mash of parts unlike anyone else's in the world, so collaboratively diagnosing things over the internet becomes damn near impossible in my mind.
We all know the 3 things diesels need to run, and the fact that it eventually starts and idles proves it is at least getting those 3.
Beyond those 3 things there are a million things that take over to make it go up and down the road optimally and efficiently.
I think this is one of the well known issues with the AAZ head on a 1.6 is poor cold starts. You have definitely proven that with the sound clip.
I'm afraid it's just the nature of the beast you have created...
I would completely rule out compression and air leaks in the fuel then just get to tinkering/experimenting with slightly different static timing values next.  Just change one thing at a time and test.
You are in uncharted territory, no one out there is going to be able to tell you, "oh yea just set this thing to x.xxmm and turn this screw here and this one here and you should be good", it is all up to you.
Reply #21November 18, 2014, 05:12:14 am
« Reply #21 on: November 18, 2014, 05:12:14 am »
Sounds like a ton of air in pump and possibly an idle spring that doesn't belong in the vw pump
Reply #22November 18, 2014, 05:28:00 am
« Reply #22 on: November 18, 2014, 05:28:00 am »
Ja, air in the IP for sure... beyond that will be hard to say until air is gone.
Reply #23November 18, 2014, 06:27:06 am
TimpanogosSlim
  • 590
« Reply #23 on: November 18, 2014, 06:27:06 am »
yeah the air is a confirmed problem
Idle spring though? I know my pump is a mongrel and i have a line on a VW turbo pump, but how do you get a wrong idle spring from that recording? just asking so i can understand, i mean
Reply #24November 18, 2014, 07:15:36 am
« Reply #24 on: November 18, 2014, 07:15:36 am »
I am guessing. You have said you had issues with letting the clutch out and stalling. Fix the air and see if it is the spring or you need more main fuel or something else. But the way it idled sounds like something is up with that spring if it is not the same as the vw one. Air seems to be a huge problem as it should never take that long to start. Please tell me you have seated the rings and not let it idle a ton.
Reply #25November 18, 2014, 07:36:29 am
TimpanogosSlim
  • 590
« Reply #25 on: November 18, 2014, 07:36:29 am »
I did have my foot on the pedal for the first bit of running there.
It has idled a total of maybe 5 minutes. Adjusting the shift linkage and fuel solved the stalling issue and it has been around the block once.
Reply #26November 18, 2014, 07:50:05 am
« Reply #26 on: November 18, 2014, 07:50:05 am »
Well I would say most of the issue is the air in the fuel then.
Reply #27November 18, 2014, 08:21:39 am
EcoTX
  • 113
« Reply #27 on: November 18, 2014, 08:21:39 am »
Can you get a bunch of pictures or video of the clear return line coming out of the pump while cranking and idling?
A properly working Bosch VE pump should be self priming and also not need any help pulling in fuel on its own from the tank.
They are pretty tolerable of quite a bit of air ingestion actually, don't be concerned if it is just a few bubbles.
Here's my return line priming up for the first time with a pump and filter full of fuel, tons of bubbles/foam/air, you can clearly see it.
http://youtu.be/QdA8YgaqnvA?t=1m30s
Then here it is right after starting...
http://youtu.be/QdA8YgaqnvA?t=3m10s
Kind of hard to tell, but the return line is solid foamy bubbles from that point until the end of the video, but the engine is running fine. The pump is just purging itself of the air as designed.
So don't be too alarmed if you see some air/bubbles/foam in the line, at idle circulation rates it could take a very long time to completely purge itself of air.
It is best really to take it for a drive through varying higher RPM's to really get all the air out quickly.
Reply #28November 18, 2014, 08:26:42 am
TimpanogosSlim
  • 590
« Reply #28 on: November 18, 2014, 08:26:42 am »
I may be able to. I forgot to look at the lines immediately before this startup. When i last checked under the hood a couple days ago, it had one small bubble in the tank return.
After this startup, there were several large bubbles in the tank return, and the leak line nearest the capped nipple was almost all air. Thus my presumption that the cap leaks.
I have a highish-end point-n-shoot digital camera that records 1080p video, a tripod, and some halogen work lights, so a startup video is doable.
I know i don't need the lift pump, but it was already installed when i bought the car, and sure is handy for priming.
« Last Edit: November 18, 2014, 08:30:12 am by TimpanogosSlim »
