mTDI Mechanical TDI Conversions
Idle
Topic: Idle (Read 4242 times)
October 15, 2014, 09:10:55 am
rodpaslow
Idle
October 15, 2014, 09:10:55 am »
I've read some post in this forum about mtdi idle. I'd like mine to be a bit higher right around 800-850. If I adjust the fuel screw down and adjust the idle back up it will start to hang at about the same spot every time. Is there a trick to getting it higher without it hanging?
I've also read a post about injectors. I know mine need to be changed. I get some blue smoke at startup and first minutes or so when cold (around 32°F, 0°C). Would re-newing/changing nozzles help this and the idle?
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
October 16, 2014, 09:04:04 am
Re: Idle
October 16, 2014, 09:04:04 am »
It sounds like you may be fully compressing the idle spring. You may want to stretch it a little.
October 16, 2014, 11:30:40 am
rodpaslow
Re: Idle
October 16, 2014, 11:30:40 am »
Thanks. I think I may change the nozzle first. See what happens and if I still need to pull the top off and see if I can do that. I have a few other pumps, would replacing the idle spring with a stronger one do the same thing? the LR spring seemed pretty weak to me.
October 16, 2014, 06:35:24 pm
Re: Idle
October 16, 2014, 06:35:24 pm »
Yes, a stronger idle spring would accomplish the same thing. I don't recall what idle spring I used in my Rover pump. I think it was the stock rover spring. Idle is rock solid at 890 rpms. On Cummins 4BTA base pumps I always used the Cummins spring and idle is always solid.
October 16, 2014, 07:06:14 pm
Re: Idle
October 16, 2014, 07:06:14 pm »
My Rover pump definitely wants to idle right around 900 too. I have it bumped up slightly from there for vibration purposes but you can let the clutch out and it will hold about 850-875 happily.
Idle
