Author Topic: Having trouble getting engine on time  (Read 7822 times)
June 26, 2014, 01:57:03 pm
Diesel_Zuk
  • 182
« on: June 26, 2014, 01:57:03 pm »
So I checked the timing on my ecodiesel, to see if that is why it wasn't starting. I noticed the mark on the flywheel was just slightly past the mark of where it's supposed to be. I took belt off, and tried to correct it, but noticed every time I tensioned the belt, it would turn it just a hair past the mark again. Am I just doing something wrong? I have the cam lock in place, and the pump pinned.
Reply #1June 26, 2014, 03:35:29 pm
Re: Having trouble getting engine on time
« Reply #1 on: June 26, 2014, 03:35:29 pm »
If the crank moves during the belt tensioning process, then you are doing it wrongly.  Is the cam sprocket loosened on the shaft?It should be.  Did you rotate the crank a few degrees counter-clockwise and then back to TDC without going past so that all of the slack is in the tensioner area?  You should have.  Pump pin should not be in place when tensioning the belt although there is usually enough slop in the pin that it doesn't matter.
Reply #2June 26, 2014, 04:28:12 pm
Diesel_Zuk
  • 182
« Reply #2 on: June 26, 2014, 04:28:12 pm »
I actually did forget to loosen the cam bolt, maybe that's where I went wrong.
Reply #3June 26, 2014, 05:23:37 pm
« Reply #3 on: June 26, 2014, 05:23:37 pm »
If you didn't loosen the cam bolt or pull the pin from the injection pump, then you also didn't do the CCW and then back to TDC without going past.  If you don't, then the crank will move and the pump and cam timing will be retarded.
Reply #4June 27, 2014, 01:10:01 pm
Diesel_Zuk
  • 182
« Reply #4 on: June 27, 2014, 01:10:01 pm »
How do you get the cam sprocket loose? I broke the bolt loose using the cam lock tool, but I have no way of hitting the back side with a soft faced hammer, as the bentley manual suggests since the back timing plate is there. There is a small hole, and somebody suggested using a small punch, but it is just eating up the sprocket, and I don't want to damage it. What tool do I need?
Reply #5June 27, 2014, 03:07:43 pm
Re:
« Reply #5 on: June 27, 2014, 03:07:43 pm »
A punch is what I use. Just make sure it is a flat punch, not a point! One good whack is all it takes.
Reply #6June 27, 2014, 05:01:34 pm
« Reply #6 on: June 27, 2014, 05:01:34 pm »
Please do not use the cam lock tool to loosen or tighten the cam sprocket bolt. You will eventually break the cam. Hold the cam sprocket with something.
Reply #7June 27, 2014, 05:12:53 pm
Diesel_Zuk
  • 182
« Reply #7 on: June 27, 2014, 05:12:53 pm »
Thanks for the heads up. Any suggestion what to use?
Reply #8June 27, 2014, 05:13:42 pm
Diesel_Zuk
  • 182
Re:
« Reply #8 on: June 27, 2014, 05:13:42 pm »
I did use a flat punch, still nothing, it is still denting up the sprocket a little bit, I don't want to damage anything.
Reply #9June 27, 2014, 05:16:38 pm
Re:
« Reply #9 on: June 27, 2014, 05:16:38 pm »
You can get a cam pulley holder tool fairly inexpensively, I got mine at Princess Auto. You can also use a crescent wrench on a cam lobe provided everything is CLEAN.
Reply #10June 27, 2014, 05:26:10 pm
« Reply #10 on: June 27, 2014, 05:26:10 pm »
Use a bigger hammer or take a longer swipe at it. Unless someone over torqued it, it will come off but it takes a quick sharp wack.
Reply #11June 27, 2014, 06:58:17 pm
Diesel_Zuk
  • 182
« Reply #11 on: June 27, 2014, 06:58:17 pm »
I got it finally, I got the biggest flattest punch I could fit in the hole, and a big long swipe. Is it normal that there is a little tiny slack in the cam lock tool and the head? I tried my best, but I think that still threw off my timing by a little bit, not sure if it will be a big deal or not.
Reply #12June 27, 2014, 06:59:49 pm
Diesel_Zuk
  • 182
« Reply #12 on: June 27, 2014, 06:59:49 pm »
I went to put my starter on, and I ran into this, I don't remember seeing it before, and none of the starter bolts fit through the hole, any idea where it goes? I'm super close to being able to try and start this thing again.
Reply #13June 27, 2014, 07:52:51 pm
Re:
« Reply #13 on: June 27, 2014, 07:52:51 pm »
Yes, the cam lock tool isn't a tight fit on its own. You are supposed to use a pair of feeler gauges with even thickness under each side to make a snug fit.
I'm guessing that wire is your chassis ground?
Reply #14June 27, 2014, 08:12:06 pm
Diesel_Zuk
  • 182
« Reply #14 on: June 27, 2014, 08:12:06 pm »
I followed it, it goes to the starter. This some beach is driving me crazy. I had the starter rebuilt by a reputable shop, as opposed to buying used. I retimed everything, put starter on, charged battery, and voila!!!! It still cranks extremely slow. I know it is not my engine locked up or anything, I can turn by hand with a ratchet good and smooth.
