Author Topic: Compression Test Injector Adapter for 1.6 Mk2 Engine???  (Read 17402 times)
Reply #15May 22, 2014, 10:22:11 am
ftm1776
  • 149
Re: Compression Test Injector Adapter for 1.6 Mk2 Engine???
« Reply #15 on: May 22, 2014, 10:22:11 am »
Go to prothe, buy his guage and adapter for like $20.
8v-0f-fury,
Who or what is "prothe"??
HF adapter does need collar around the part that actually threads into the engine.  In addition to that collar I put the copper washer between the collar and the adapter body.  So I have the heatshield to the collar and then the washer and then the adapter.
ORCoaster,
Where did you get the copper washer? Why did you use it?? Is it necessary to use it, in your opinion?
I think I under stand that the compressed chamber volume must be the same when testing as when the injector is in place. Although the "volume" of the collar is small, it's presence does add or subtract substantially to or from the compressed volume thereby affecting the compression reading. I suppose that one could take a compression reading with and without the adapter just to see what difference it might make.
So, does the HF kit have every thing I need?
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #16May 22, 2014, 10:59:58 am
92EcoDiesel Jetta
« Reply #16 on: May 22, 2014, 10:59:58 am »
I don't think a schrader is up to the task... 500psi?  The HF fitting is a high pressure coupler that connects to the hose with a locking collar.
The quick coupler serves a different function than the Schraeder valve (tire valve), which is necessary in all compression testers to hold the pressure within the compression tester.
« Last Edit: May 22, 2014, 11:23:32 am by 92EcoDiesel Jetta »
Reply #17May 22, 2014, 12:02:19 pm
92EcoDiesel Jetta
« Reply #17 on: May 22, 2014, 12:02:19 pm »
Some pics of my HF injector adapter, the Prothe one is supposed to be the same.
You can stick a pencil in the hole about 1.5". Not visible, the Schraeder valve is at the tip of the silver colored quick coupler. That is a lot of extra volume which will lower the compression reading by a lot. I never use that injector adapter for that reason. I go in the glow plug hole.
Reply #18May 22, 2014, 03:11:33 pm
« Reply #18 on: May 22, 2014, 03:11:33 pm »
The kit has the copper washer in it.  One of the 19 pcs If I remember correctly.
I use that to get a good and proper seal between the roughly cast adapter and the collar.  Crude casting but functional.  Same reason we use copper between the fuel line to fuel pump fittings.
I wouldn't think you would see that much of a difference in values with or without the collar but I would love to see the results.  Kind of reference this Schraeder valve discussion as well.  So do a measure or three with the injector body all properly installed, all the parts in place then pull the collar out of the mix.  Then measure in GP hole for comparison purposes.  Could be very enlightening.
ORCoaster,
Mark I can't believe you said this:
As it's below the one way valve, it would fill up and discharge as part of the engine chamber every stroke. Further guessing, I'd say that that was approaching +15% of the compression chamber, or nearing 75psi on a good day...
Not crucial if you are just comparing cylinders, but might wrongly influence someone to embark on a $2000 rebuild if they believed the score.
1600 cc engine /4cylinders =400 cc per   1/400=? .0025 or .25% not even close to 15%.  So if you are trying to measure 600 PSI and you are off .25% can you detect that on the face of the gauge?   That is 1.5 lbs,  I can't differentiate that on my gauge at all.  Given the increments are much greater than 1 lb or even 5 lbs apart.
Mountain of a molehill I say.
« Last Edit: May 22, 2014, 03:20:34 pm by ORCoaster »
Reply #19May 22, 2014, 04:03:58 pm
Re:
« Reply #19 on: May 22, 2014, 04:03:58 pm »
You are measuring the wrong volume.
The compression test is measuring the pressure with the piston at the top of the cylinder. The only unfilled volume is the inside of the prechamber and a tiny bit above the piston. The volume of the adapter is a substantial portion of the prechamber.
Reply #20May 22, 2014, 04:59:48 pm
Mark(The Miser)UK
  • 1557
« Reply #20 on: May 22, 2014, 04:59:48 pm »
ORCoaster,
LOL...
The collar [spelt it correctly this time!] does indeed have little impact on the cc of the cylinder. This is great if a compression tester operated @BDC, but alas they operate @TDC when the space above the piston is only about 6 cc to give your 23:1.  Wait that's wrong, (400 + X): X :: 23:1 So if X is air space above cylinder swept, (400 +18)18 is 23.2 . So it's about 5%, if collar is 1cc. OK so it's nearer 25psi. However a poor adaptor adds plenty more.
My tester is a Snap-on similar to below. There is a pressure relief valve up near the gauge, but there is also a brass to brass one way valve down near the adapter. A shriver valve, unless purpose built would struggle because of the plastic seal. Someone volumize the collar and washer to help my in my defense ;D
 EDIT my post was a little slow, and has been replicated...
http://buy1.snapon.com/products/diagnostics/mt33c.asp?tool=all&Item_id=16694&PartNo=MT33C&Price=240.3&Desc=&SUB_Cat_ID=3057049&SUB_Cat_NAME=Diesel+Compression&Cat_ID=3057045&Cat_NAME=Fuel+And+Engine+Systems&group_id=1429&group_NAME=Gauge&store=canada&dir=catalog&pix=objects%2F33900%2F33813.JPG&email=true
Mark-The-Miser-UK
Reply #21May 22, 2014, 05:02:16 pm
92EcoDiesel Jetta
« Reply #21 on: May 22, 2014, 05:02:16 pm »
Collar + copper washer is necessary to get a good seal so it does not leak past the threads. The
collar dimensions:
0.44" H
0.67" o.d.
0.555" i.d.
volume 0.74 cubic centimeters
empty space in adapter dimensions:
1.6" deep
0,33" i.d.
volume=2.24 cc
Someone check my math.
total extra volume 2.98 cc
What's the difference in cc from a 1 notch to a 3 notch head gasket? Is it less than 2.98 cc?
Reply #22May 22, 2014, 07:24:29 pm
8v-of-fury!
Reply #23May 22, 2014, 07:40:33 pm
« Reply #23 on: May 22, 2014, 07:40:33 pm »
Collar
(.67/2)2 * 3.14 = 0.3523865in2
- ((.555/2)2 * 3.14 = 0.241799625in2)
= 0.110586875in2
X .44" = 0.048658225in3
0.048658225in3 = .797365447 cc
Cavity
(.33/2)2 * 3.14 = 0.0854865in2
0.0854865in2 * 1.6 = 0.1367784in3
0.1367784in3 = 2.24139639cc
total = 3.038761837cc
1notch max piston protrusion = .86mm
3notch max piston protrusion = 1.02mm
difference = .16mm
cyl diameter 77mm (2nd  overbore)
((77/2)2 *3.14) * .16 = 744.6824mm3
744.6824mm3 = .744cc
Reply #24May 22, 2014, 08:14:33 pm
« Reply #24 on: May 22, 2014, 08:14:33 pm »
I'll be damned.... I never looked down there.
(Reminds me of a joke.  8) )
Reply #25May 22, 2014, 09:25:37 pm
« Reply #25 on: May 22, 2014, 09:25:37 pm »
I like math but was just going to take the washer and adapter out of my kit and drop them in a known amount of water to see what overflowed and measure that with a small syringe.  That is not necessary now.  thanks.
Still would like to see the measurements on the cylinder pressure.
Reply #26May 23, 2014, 08:52:56 am
92EcoDiesel Jetta
« Reply #26 on: May 23, 2014, 08:52:56 am »
http://www.hansautoparts.com/DieselCompressionGauge.aspx
http://www.hansautoparts.com/16CompressionFitting.aspx
$16 total. Seriosuly, it works perfectly..
You did not answer my question. If it is the same as the HF adapter, it has a serious fault.
Reply #27May 23, 2014, 08:56:23 am
92EcoDiesel Jetta
« Reply #27 on: May 23, 2014, 08:56:23 am »
A shriver valve? Never heard of one. More details please!
Reply #28May 23, 2014, 09:02:15 am
92EcoDiesel Jetta
« Reply #28 on: May 23, 2014, 09:02:15 am »
With the known extra volume created by the poorly designed adapter, the difference in compression can be calculated.
Reply #29May 23, 2014, 09:05:57 am
92EcoDiesel Jetta
« Reply #29 on: May 23, 2014, 09:05:57 am »
Collar
= 0.110586875in2
Cavity
difference = .16mm
My numbers are close. I did it while watching TV, using an online volume calculator which round off the numbers entered.
« Last Edit: May 23, 2014, 11:51:06 am by 92EcoDiesel Jetta »
