aaz turbo option
Pages:
7
8
9
10
11
12
13
Topic: aaz turbo option (Read 55515 times)
Reply #135
February 10, 2015, 01:33:22 pm
mark3kid
Re: aaz turbo option
Reply #135 on:
February 10, 2015, 01:33:22 pm »
What am I checking the Injectors for?
When that turbo hits full boost you will forget all about the work to get you there, I promise It's pretty similar to women giving birth... - Alcaid
Reply #136
February 10, 2015, 01:42:31 pm
Reply #136 on:
February 10, 2015, 01:42:31 pm »
to see if it leaks/drips before it actually sprays, and also check the spray pattern
Reply #137
February 11, 2015, 02:06:16 pm
mark3kid
Reply #137 on:
February 11, 2015, 02:06:16 pm »
They shouldn't because they were rebuilt and balanced by Giles and have less then 20k kms on them. But possible
Reply #138
April 16, 2015, 02:36:21 pm
mark3kid
Reply #138 on:
April 16, 2015, 02:36:21 pm »
Hey guys. So I'm looking for ARP rod bolts asap and I need a part number. I can't find it on google or the website so if someone could point me in the right direction that would be great!
Reply #139
April 16, 2015, 03:51:14 pm
Reply #139 on:
April 16, 2015, 03:51:14 pm »
FAQ
Round 2
Reply #140
April 17, 2015, 05:55:59 pm
mark3kid
Reply #140 on:
April 17, 2015, 05:55:59 pm »
I tried and still have had really bad luck. Id much rather find it on my own trust me but if one of you guys could point me in the right direction it would be great! These are the only thing keeping my car from going together
Reply #141
April 17, 2015, 09:14:26 pm
Reply #141 on:
April 17, 2015, 09:14:26 pm »
http://www.vwdiesel.net/forum/index.php/board,13.20.html
about 2/3 down the page is the thread titled ARP Part numbers
Round 2
Reply #142
April 18, 2015, 02:41:15 am
mark3kid
Reply #142 on:
April 18, 2015, 02:41:15 am »
I see now but they only mention it for the 1.6 and 1.7
Reply #143
May 29, 2015, 07:50:18 am
mark3kid
Reply #143 on:
May 29, 2015, 07:50:18 am »
Hey guys I need desperate help! I got the car fully rebuilt and it makes great power but it won't make over 20psi and my egts are to high! So the waste gate on the turbo. When its closed it should make full boost correct? Anything I can check to see why I'm not making more boost.
Reply #144
May 30, 2015, 12:44:48 am
Alcaid
Reply #144 on:
May 30, 2015, 12:44:48 am »
Have you added a ball and spring type boost controller to dial in the boost? Enough preload on the wastegate? We have seen over 45psi with the exact same turbo on a 1.6TD when adding lots of fuel
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound
Reply #145
May 30, 2015, 04:35:56 am
jmaddocks
Reply #145 on:
May 30, 2015, 04:35:56 am »
I'd check the WG preload first. For troubleshooting purposes, disconnect the boost line going to the WG actuator (make sure you cap the end which goes to the manifold -- you don't want a boost leak). Increase WG preload incrementally, driving the car each time to check boost levels. It needs a lot more preload than you think.
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #146
May 30, 2015, 05:26:40 am
Reply #146 on:
May 30, 2015, 05:26:40 am »
Yeah I have a hard time keeping mine under 35 psi now that I fixed the boost leak.
Round 2
Reply #147
May 30, 2015, 05:42:19 am
Gizmoman
Reply #147 on:
May 30, 2015, 05:42:19 am »
I can't make over 20 PSI either and have the gate wired shut. For me it's a fueling issue I believe as my EGT's don't go over 1100 F.
The HE200 turbo is still awesome
Reply #148
May 30, 2015, 08:50:06 am
mark3kid
Reply #148 on:
May 30, 2015, 08:50:06 am »
I have the wastegate wired shut and the line blocked off. I have a lot of fuel! But just can't make over 20psi
Reply #149
May 30, 2015, 10:44:56 am
Alcaid
Reply #149 on:
May 30, 2015, 10:44:56 am »
If that is correct it would mean you have a boost leak somewhere
Pages:
7
8
9
10
11
12
13
aaz turbo option
