Author Topic: Leaking coolant, can't find it.  (Read 9749 times)
Reply #15September 23, 2013, 11:54:10 am
Re: Leaking coolant, can't find it.
« Reply #15 on: September 23, 2013, 11:54:10 am »
I would put a floor jack on that point under the front door and raise it up.  Or drive onto some ramps and then just shimmy under the engine and look up at the back of it with a good light.  Even if there isn't a heater in there one of the three freeze plugs might be weeping coolant.
Reply #16September 23, 2013, 02:59:19 pm
air-cooled or diesel
« Reply #16 on: September 23, 2013, 02:59:19 pm »
my thoughts too, take a look
But, never get underneath a car without jack stands or good ramps, stands are best, I had a problem with ramps bending parts as car went up them.
Reply #17September 23, 2013, 04:59:24 pm
« Reply #17 on: September 23, 2013, 04:59:24 pm »
Read the 1st post. It's a Jeep Cherokee. The diesel one, that they sold in Europe.
You shouldn't need any kind of ramp or jack to crawl under a Jeep Cherokee.
5 euros says it's the heater control valve, water pump or radiator... I replaced three of them (and 3 water pumps and 3 radiators) during the 10 years I owned a Cherokee.
Reply #18September 23, 2013, 07:39:22 pm
« Reply #18 on: September 23, 2013, 07:39:22 pm »
Three very good reasons not to own a Jeep:
But there was a day in time back before the seventh planet was discovered that I was the unfortunate owner/mechanic to a Jeep Commando.  What a freezer box on wheels.  The UP of Michigan knows no mercy for such a tin roof sundae.
I insulated it the next summer and put carpeting throughout.
Reply #19December 12, 2013, 04:33:38 am
AdrianD
« Reply #19 on: December 12, 2013, 04:33:38 am »
After so many months I still haven't found the leak but in my defense I did not have time to get it tested. After a longer drive there still is a strong coolant smell so its definitely leaking on the block somewhere.
There's a new addition to the garage, a 94 Miata which is tons of fun :D
« Last Edit: December 12, 2013, 04:35:19 am by AdrianD »
Reply #20December 12, 2013, 08:27:31 am
Turftech
  • 113
« Reply #20 on: December 12, 2013, 08:27:31 am »
I typically pressurise the system with a tester then place a clean piece of cardboard under the motor and watch for any stains. It might also be burning the coolant if it is a partially blown head gasket.
'90 Jetta GL TD  570'000 Kms and counting (Gave her to a friend)
'92 Passat G60 Syncro Wagon 180'000kms. TDI conversion project
'87 Jetta Coupe 325'000kms. MF IDI conversion project
Reply #21April 01, 2014, 01:12:10 am
AdrianD
« Reply #21 on: April 01, 2014, 01:12:10 am »
Found the damn leak !!!
It was a hose which was very accessible, it never looked moist, never looked like it had a leak but at one point it started to swell up and then it developed a big hole. After changing it out the coolant leak stopped.
Reply #22April 01, 2014, 06:31:47 pm
« Reply #22 on: April 01, 2014, 06:31:47 pm »
This is how some people manage their problems.  Drive it until it breaks and then fix it.  Sometimes that costs more but sounds like you snuck by.  This time.
