Author Topic: Diving in.  (Read 25742 times)
Reply #75September 12, 2013, 05:10:56 pm
icyhotpatch
  • 117
Re:
« Reply #75 on: September 12, 2013, 05:10:56 pm »
I do have a Bentley just dont have much time to read it page to page. My gasket is 3 notch. The head bolt size is confusing to me as well what engine codes go with what bolt sizes.
Thanks for the tip on the shaft play. Ill do that tomorrow if I get time. Hopefully its something else. If its the intermediate shaft engine must come out.
Reply #76September 13, 2013, 04:20:55 pm
icyhotpatch
  • 117
Re:
« Reply #76 on: September 13, 2013, 04:20:55 pm »
I think I am going to drop the motor did compression test today all with parameters but I am not able to see the leak at all. It seems to be coming from the front of the motor on the lower half now that the valve cover leak has been dealt with. No play in the intermediate shaft pulley loosened but did not remove the belt but doesnt rule it out. I think dropping the motor and trans  will make it quicker and be more effective to clean the motor after the leak is fixed.
Any tips? And if it is the intermediate shaft seal the motor must be removed to replace the seal anyway or atleast thats what my Bentley says.
So wish me luck
Reply #77September 13, 2013, 05:11:18 pm
Gizmoman
  • 1301
Re:
« Reply #77 on: September 13, 2013, 05:11:18 pm »
Reply #78September 13, 2013, 07:41:25 pm
icyhotpatch
  • 117
Re:
« Reply #78 on: September 13, 2013, 07:41:25 pm »
Thanks I know you guys are concerned because of my lack of VAG wisdom but I must learn through my mistakes and triumphs.
Reply #79September 23, 2013, 04:19:04 am
icyhotpatch
  • 117
Re:
« Reply #79 on: September 23, 2013, 04:19:04 am »
Anybody got me a link to where I can buy a triangle socket for the ip?
Reply #80September 23, 2013, 04:22:33 am
icyhotpatch
  • 117
Re:
« Reply #80 on: September 23, 2013, 04:22:33 am »
Dont have alot of time but the car has been fun to work on so far. Maybe its because unlike my other cars its just awesome.
Reply #81September 23, 2013, 07:35:24 am
flowmastergfunk
  • 129
Re:
« Reply #81 on: September 23, 2013, 07:35:24 am »
:thumbup:
Bravo. That's the attitude that keeps you going! We all had to start somewhere. It's been 6+years since I got my first vw diesel and I am still learning. I am excited to get into the turbo world!
as for the triangle socket...good luck finding it! I made mine by taking a 13mm 6-point and grinding down 3 of the sides with a dremel until it fit the bolt.
Reply #82September 23, 2013, 09:24:28 am
icyhotpatch
  • 117
Re:
« Reply #82 on: September 23, 2013, 09:24:28 am »
I just didnt want to screw up with the dremel and have to go buy another 13mm hate wasting tools like that. I have most of the ip disassembled. Just need those bolts out.
Reply #83September 23, 2013, 10:20:41 am
flowmastergfunk
  • 129
Re: Diving in.
« Reply #83 on: September 23, 2013, 10:20:41 am »
Go slow :P
Reply #84September 23, 2013, 11:50:26 am
Re: Diving in.
« Reply #84 on: September 23, 2013, 11:50:26 am »
In a pinch I have used the thin vise grip pliers I own.  One on the flat one on the rounde part and quick snap to get them to loosen up.  One shot try generally.
Reply #85September 28, 2013, 05:10:27 pm
icyhotpatch
  • 117
Re:
« Reply #85 on: September 28, 2013, 05:10:27 pm »
Got it out but now this wont come out:
Reply #86September 28, 2013, 06:56:25 pm
audilvr
Re: Diving in.
« Reply #86 on: September 28, 2013, 06:56:25 pm »
Reply #87September 28, 2013, 07:12:19 pm
icyhotpatch
  • 117
Re:
« Reply #87 on: September 28, 2013, 07:12:19 pm »
I might order that but got them out already
Reply #88September 28, 2013, 08:47:47 pm
Re: Diving in.
« Reply #88 on: September 28, 2013, 08:47:47 pm »
A flat screwdriver and hammer work don't they?  Counterclockwise thread on this one?  Been awhile since I disassembled that top side.
Reply #89September 29, 2013, 03:46:48 am
icyhotpatch
  • 117
Re:
« Reply #89 on: September 29, 2013, 03:46:48 am »
There is a 5mm allen key then the big flathead looking thing
