Author Topic: 91 Eco Diesel idle?  (Read 8669 times)
Reply #15August 18, 2013, 07:16:44 pm
Re: 91 Eco Diesel idle?
« Reply #15 on: August 18, 2013, 07:16:44 pm »
Yep, TD.
Reply #16August 18, 2013, 07:18:18 pm
DAKOTAKIDD
  • 114
« Reply #16 on: August 18, 2013, 07:18:18 pm »
So is there something on it that could suck in the vapours from the brake clean?
Reply #17August 18, 2013, 07:26:23 pm
« Reply #17 on: August 18, 2013, 07:26:23 pm »
I doubt it.
More likely a loose clamp on the intake piping, or fumes got sucked into the hockey-puck if the collar is loose.
Reply #18August 18, 2013, 08:29:27 pm
« Reply #18 on: August 18, 2013, 08:29:27 pm »
Try a shot of brake clean at the hockey puck and see what happens.  Just make em short shots.  Maybe the gasket on the VC has a crack on it.    Hoses loose in other places?
Kind of reminds me of finding a vac leak on a gasser with carb cleaner.
Reply #19August 19, 2013, 04:31:24 pm
DAKOTAKIDD
  • 114
« Reply #19 on: August 19, 2013, 04:31:24 pm »
I will try a shot when I get some more brake cleaner or something else that combusts..
I will post back..
Thx
Reply #20August 19, 2013, 07:39:29 pm
jboogie13
  • 175
« Reply #20 on: August 19, 2013, 07:39:29 pm »
I would suggest switching to carb cleaner. Brake parts cleaner has additives in it that become toxic when burned. One shot contains more than enough to put you out of commission if inhaled.
I know the tailpipe is a long way from where you are working, but why take the risk?
Reply #21August 19, 2013, 07:45:08 pm
« Reply #21 on: August 19, 2013, 07:45:08 pm »
Wow, no bull eh? I had no idea.. I never really did feel comfortable with ANY aerosol type propelled can of carcinogens..
Reply #22August 19, 2013, 08:10:52 pm
« Reply #22 on: August 19, 2013, 08:10:52 pm »
Non-chlorinated brake cleaner will not make phosgene when burned. That said, it is not very healthy or fun to get a snootful.
http://www.crcindustries.com/faxdocs/msds/5088.pdf
Reply #23August 20, 2013, 05:07:55 am
jboogie13
  • 175
« Reply #23 on: August 20, 2013, 05:07:55 am »
ah yes, forgot that little detail..oops  :-X
Reply #24August 20, 2013, 05:58:04 am
« Reply #24 on: August 20, 2013, 05:58:04 am »
No worries. Abundance of caution is much better than the opposite.
I have accidentally inhaled a blast of vapor when spraying non-C cleaner on a hot engine - ugh.
A long while back, I was shown how guys that smoked while working on R12 AC systems were at significant risk. (That was when you could smoke in a dealership shop.)
