Author Topic: eco diesel cat on mtdi?  (Read 7282 times)
August 08, 2013, 06:35:52 pm
bbob203
  • 1789
« on: August 08, 2013, 06:35:52 pm »
I have a used cat from a 92 eco diesel would it bog down my exhaust flow much if I run it on my passat? I'm sick of stinky exhaust and also hope it can cut down on some cabin noise.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1August 08, 2013, 07:03:14 pm
Re: eco diesel cat on mtdi?
« Reply #1 on: August 08, 2013, 07:03:14 pm »
How do they look inside? Are they restrictive? People keep their mk4 cats on when they make big power.. BUT they are likely different than a 92 ECO.
Reply #2August 08, 2013, 07:14:02 pm
« Reply #2 on: August 08, 2013, 07:14:02 pm »
if he would get the tail pipe from under rear bumper it be lots more quiet and less smelly.. cabin vent between bumper cover and quarterpanel so sux it all in when window/hvac used...
Reply #3August 08, 2013, 07:17:27 pm
« Reply #3 on: August 08, 2013, 07:17:27 pm »
The ECO exhaust is fairly small.  You can get a universal diesel cat from Summit for whatever size pipe.  My next exhaust will be with a universal cat and a spiral flow muffler.  When I get around to doing it I would like to make a recording of the before (straight pipe) and after.
Reply #4August 08, 2013, 07:24:52 pm
« Reply #4 on: August 08, 2013, 07:24:52 pm »
2.5" turbo back.. 6" past bumper...
he also has gap in body by shifter... 02j stuiff fits like crap and there is lotsa noise too.. more w/cat and odd hollow sounds when gutted.. on gasser at least..
the loudest passat exhaust i ever used on my td stuff was the stock system... it made so much interior noise... straight pipe is so much more quiet.. and runs better  ::)
Reply #5August 09, 2013, 01:49:09 am
bbob203
  • 1789
« Reply #5 on: August 09, 2013, 01:49:09 am »
my thinking with the cat I have is to chop the pipe of at each end and weld a flange on one end and 2.5" pipe into other end and chop off muffler and run straight pipe.
03 Jetta wagon TDi
Reply #6August 09, 2013, 05:59:32 am
thegimpster
  • 243
    • VDubShirts.com Awesome VW themed shirts with attitude
« Reply #6 on: August 09, 2013, 05:59:32 am »
I have a couple good cats up here if you need one bigger than the eco one. Got a mk4 one i think and a mk3.5 cabby one with like 100k miles on it.
Check out www.vdubshirts.com for cool VW themed shirts with attitude.
Reply #7August 09, 2013, 06:26:11 am
bbob203
  • 1789
« Reply #7 on: August 09, 2013, 06:26:11 am »
diesel and gas are different I think.
03 Jetta wagon TDi
Reply #8August 09, 2013, 06:41:27 am
« Reply #8 on: August 09, 2013, 06:41:27 am »
i personally think cat diesel stinks vs non cat... the b4 is cat to straight pipe if ya wanna wiff it ben.. too bad it so freegin bent to reuse..
Reply #9August 09, 2013, 09:32:28 pm
« Reply #9 on: August 09, 2013, 09:32:28 pm »
My non-cat 1.9 IDI and my non-cat 1.9 TDI smell worlds different. But the 1.9 IDI smelled the same as the "catted" 1.6's and 1.9's I've smelt.
Reply #10August 12, 2013, 08:10:26 am
« Reply #10 on: August 12, 2013, 08:10:26 am »
If you need a cat, get the Magnaflow diesel one.  It's way less restrictive than the factory ones plus you can get it in a 2.5" or even larger size.  I've got one on Jezzie.
There's a definite difference in the cat vs. non-cat smell plus there is some sound attenuation.
Reply #11August 12, 2013, 09:52:26 pm
smokeinmirrors
  • 38
« Reply #11 on: August 12, 2013, 09:52:26 pm »
I am thinking about getting one of these for a reduction in smell. No emmisions inspections where I live, but I just don't want to be the stereotypical stinky diesel. Have 2" out of the turbo and 2.25" the rest of the system - I noticed in the 2" cats there is a metal core available, but in 2.25" it is ceramic only. Should I go with the bigger ceramic core, or would the smaller metallic core be the way to go?
http://www.summitracing.com/parts/mpe-53004dm/overview/
http://www.summitracing.com/parts/mpe-54105d
'86 Golf - AHU m-TDI, Garrett GT2052w
Reply #12August 15, 2013, 03:36:02 pm
Re: Re: eco diesel cat on mtdi?
« Reply #12 on: August 15, 2013, 03:36:02 pm »
Mine is ceramic and has been on the car for about 4 years now. I have a 2.5".
I wouldn't  say the cat removes the smell, really it just changes it. My exhaust is still plenty stinky though it does smell a little less like death.
Sent from my HTC One X using Tapatalk 2
Reply #13August 16, 2013, 03:57:44 pm
bbob203
  • 1789
« Reply #13 on: August 16, 2013, 03:57:44 pm »
I'm 2.5" straight pipe from downpipe back now. 8) Ill get a Cat some day the cab noise is much quiter now.
03 Jetta wagon TDi
Reply #14August 16, 2013, 03:58:14 pm
« Reply #14 on: August 16, 2013, 03:58:14 pm »
Because the exhaust exits from under the car ? ;)
