S-PAutomotive.com
Author Topic: adding low coolant warning  (Read 3876 times)
June 18, 2013, 09:15:01 am
92EcoDiesel Jetta
« on: June 18, 2013, 09:15:01 am »
My 81 Caddy does not have a low coolant level sender in the expansion tank like on my mk2 Jetta. IMO, low coolant warning is essential to let you know of  impending overheat before it is too late.
I found an expansion tank from a 92 Cabrio with a low level sender but the big question is whether the Caddy's Westmoreland cluster has the circuitry for it. Has anyone done what I like to do and how did you do it?
« Last Edit: June 19, 2013, 09:11:40 am by 92EcoDiesel Jetta »
Reply #1June 19, 2013, 09:10:52 am
92EcoDiesel Jetta
Re: adding low coolant warning to Caddy
« Reply #1 on: June 19, 2013, 09:10:52 am »
Bump. When (year/model) did VW add low coolant warning? Do ones w/o suffer more head gasket/ overheat problems?
Reply #2June 19, 2013, 09:19:42 am
  • 7834
« Reply #2 on: June 19, 2013, 09:19:42 am »
Don't know for sure. I know 85 my jetta has it. Fatmobile IIRC did this very thing or knows of someone who did. I would think if you added the dash stuff, exp. tank, and wiring it would work no issue.
Reply #3June 19, 2013, 09:36:54 am
92EcoDiesel Jetta
« Reply #3 on: June 19, 2013, 09:36:54 am »
That would be a lot of work and lot of parts and is not the approach I would want to take. Anyone done it by some other creative ways?
Reply #4June 19, 2013, 10:05:58 am
  • 7834
« Reply #4 on: June 19, 2013, 10:05:58 am »
IDK, How much easier could it get? You have some parts, see if you could add it to a light in the existing cluster and wire it in.
Reply #5June 19, 2013, 10:10:56 am
92EcoDiesel Jetta
« Reply #5 on: June 19, 2013, 10:10:56 am »
 It's not that simple and won't work.  The low-level sender is not an on off switch
Reply #6June 19, 2013, 06:00:33 pm
damac
  • 530
« Reply #6 on: June 19, 2013, 06:00:33 pm »
I want to do it as well but of course put it off.  I already installed the reservoirs with sensors in them in my rabbit/truck
I can't speak for sure but I don't see mention of this sucker in mk1 wiring schematics in my bently?
My 85 jetta had it, and I think it had the water seperator circuit as well that earlier cars didn't.
My jetta has been daily driven by family members for years now.  That sensor once in a while freaks out, but you just check it and wiggle the plug and/or turn the car off then back on again and it mostly did a good job of working in the real world for me.  And of course the times it did catch a problem.
Sadly they were driving it with td hydro motor one day and a lower coolant hose burst.  What sucks is she told me she noticed the flashing then the gage but did NOT pull over even though I told them a million times to listen to the damn car.   Car wasn't loosing power and sounded the same so they decided to drive up and over a hill until the car locked up.
I had rescue it later.  It started but wanted to overheat every couple minutes and I had to refill the water.  Funny I think it was just a head gasket, the head appears flat and not even cracks between the valves?  Will get to the bottom of that later.
For this reason I now have auber gages hooked to airplane alarm :)  Would be neat to tie that into the low coolant alarm with a relay.
1985 turbo diesel jetta
Reply #7June 19, 2013, 07:25:15 pm
wolf_walker
  • 1201
Re: Re: adding low coolant warning
« Reply #7 on: June 19, 2013, 07:25:15 pm »
Seems like that circuit looks for a specific voltage or resistance across the two pins on the sensor yo monitor coolant level and mix ratio. It wasn't an on off switch though as was said.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #8June 19, 2013, 08:26:45 pm
Syncroincity
  • 727
« Reply #8 on: June 19, 2013, 08:26:45 pm »
Here's a nice, cheap solution; add-on level sensor switch. You choose the level it closes by location. Add an LED, and you're set.
http://www.ebay.com/itm/PP-Side-Mount-Horizontal-Water-Level-Sensor-Liquid-Float-Switch-for-Tank-Pool-/300900359399?pt=LH_DefaultDomain_0&hash=item460f0f1ce7#ht_4951wt_1157
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #9June 19, 2013, 09:08:51 pm
  • 7834
« Reply #9 on: June 19, 2013, 09:08:51 pm »
Sorry wasn't clear. Add in the wiring meant add in the parts. I don't think it is much there that you don[t have already. If you want to get really trick just drill and tap the water pump housing as it leaves the block under the IP. Being if you lost coolant that is lower than the head and you would notice your temps getting hot rather quickly. Above the head and you would be reading air, which would take much longer to heat up, if it was low.
Reply #10June 19, 2013, 09:11:11 pm
Gizmoman
  • 1301
« Reply #10 on: June 19, 2013, 09:11:11 pm »
Reply #11June 19, 2013, 09:12:20 pm
« Reply #11 on: June 19, 2013, 09:12:20 pm »
The float switch idea is not bad, if you can find one rated for ~100oC.
Would be nice to know what the OEM sensor actually does and hack a circuit for it.
Reply #12June 21, 2013, 03:28:34 am
  • 2750
« Reply #12 on: June 21, 2013, 03:28:34 am »
I deconstructed the MK2 circuitry and it's an op amp with the engine temp on one input and the level sensor on the other.
Tornado red, '91 Golf 4 door,
Reply #13June 21, 2013, 10:03:28 am
  • 5065
« Reply #13 on: June 21, 2013, 10:03:28 am »
it was available in the mk1's how ever its not very common, i think it was an 83-84 thing only and only on specific models like automatic diesel, turbo diesel, and gti.
Reply #14June 21, 2013, 10:09:28 am
  • 7834
« Reply #14 on: June 21, 2013, 10:09:28 am »
Had an 84 4 speed diesel and an 83 GTI, neither of mine had it but maybe it was certain packages?
