Author Topic: Not as lucky as I had hoped  (Read 8824 times)
Reply #15May 30, 2013, 06:24:11 pm
Re: Not as lucky as I had hoped
« Reply #15 on: May 30, 2013, 06:24:11 pm »
I have a theory that is has to do with the pulses of the alternator and the injection pump but I really don't know. The high compression is probably also a factor.
compression affects how much stress the crank goes thru..
it makes the crank slow down more, then speed up more as well..
seems like the gasser engines werent affected like the diesels tho? pretty safe assumption?
Reply #16May 30, 2013, 06:28:51 pm
Re: Re: Not as lucky as I had hoped
« Reply #16 on: May 30, 2013, 06:28:51 pm »
Well the vibration you feel in your car from the engine at idle is caused by the very speeding up and slowing down of the crank that we are taking about here - if it ran at a perfectly constant speed the engine wouldn't vibrate at all unless something was out of balance. And I'm pretty sure we all agree a diesel rattles a whole lot more than a gasser!
I definitely haven't come across many if any reports on the gasser side of crank pulley failure like we see on the serpentine equipped diesels.
Sent from my HTC One X using Tapatalk 2
Reply #17May 30, 2013, 10:56:52 pm
« Reply #17 on: May 30, 2013, 10:56:52 pm »
The G60s have a record of spinning their crank gear. They have a bit more junk attached to them though.
Reply #18May 31, 2013, 04:16:31 am
« Reply #18 on: May 31, 2013, 04:16:31 am »
i have heard of 16vs doing it too.  certainly not like an aaz tho which seems to be almost a sure thing?
Reply #19May 31, 2013, 06:19:43 am
Smoker
  • 255
« Reply #19 on: May 31, 2013, 06:19:43 am »
I've seen it ONCE on an ABA, and I've probably dealt with 100 of them. Could've easily been that the bolt was reused or improperly torqued after a seal replacement or something.
In other news, it's time to start shopping for a complete head for engine #2... excuse the newbie question, but will a head from an alh or any other tdi work with my ahu block? Alh seem to be the most common parts, at least around here.
Reply #20May 31, 2013, 06:53:37 am
« Reply #20 on: May 31, 2013, 06:53:37 am »
ALH will not work.  1Z will.
Reply #21June 03, 2013, 09:05:33 pm
Smoker
  • 255
« Reply #21 on: June 03, 2013, 09:05:33 pm »
Final diagnosis:
Lifter started doing this
Then this
This this little bugger
Came out and did this
I feel like I have closure lol. I also feel like I won't find a million little pieces of metal scattered about the oil passages.
Reply #22June 03, 2013, 09:35:53 pm
« Reply #22 on: June 03, 2013, 09:35:53 pm »
It's going to take more than 4.2% to smooth that over.
Reply #23June 05, 2013, 05:05:20 pm
Smoker
  • 255
« Reply #23 on: June 05, 2013, 05:05:20 pm »
No worries
Reply #24June 12, 2013, 04:02:44 pm
« Reply #24 on: June 12, 2013, 04:02:44 pm »
is that REAL 'shine, or the crap you get at the booze store?
Reply #25June 12, 2013, 07:53:42 pm
srgtlord
  • 797
« Reply #25 on: June 12, 2013, 07:53:42 pm »
Looks like real shine to me. Those be the infamous Mason Jars ;)
Reply #26June 13, 2013, 08:47:11 pm
Smoker
  • 255
Re: Re: Re: Not as lucky as I had hoped
« Reply #26 on: June 13, 2013, 08:47:11 pm »
That would be genuine shine, straight outta Franklin county, VA.
Reply #27June 21, 2013, 05:28:07 pm
« Reply #27 on: June 21, 2013, 05:28:07 pm »
You can buy 'Shine at the liquor store now'a days, even comes in a Mason Jar..
that stuff does indeed look like the genuine article tho, and not some knock-off you could legally buy :-p
Reply #28June 23, 2013, 02:22:08 pm
Smoker
  • 255
« Reply #28 on: June 23, 2013, 02:22:08 pm »
It doesn't taste nearly as good when you pay tax on it. ;-)
Sent from my SCH-I545 using Tapatalk 2
