Author Topic: In bolt in the out bolt hole. Stupid question.  (Read 5508 times)
Reply #15June 02, 2013, 07:08:43 am
audilvr
Re: In bolt in the out bolt hole. Stupid question.
« Reply #15 on: June 02, 2013, 07:08:43 am »
mine had two in bolts and kept blowing the rubber lines off of the injectors.
Likely wasn't the issue, as that would cause no extra pressure in the return line then normal.
Hrmmmm... I rekon it might. Just guessing, but 10-20 psi at idle.
at idle no problem...at high rpm, nothing to keep the pressure in the pump
Reply #16June 03, 2013, 06:11:34 pm
« Reply #16 on: June 03, 2013, 06:11:34 pm »
there SHOULD be nothing for the pump to build pressure against, if your return line is free of obstructions...
