Engine Specific Info and Questions > TDI Engine -General Info
Retaining ac but running water pump off serpentine on 1z
libbydiesel:
I can't find a pic and due to stuff in the way it is not really possible to get a pic of it installed in my Vanagon. The Qantum 1.6TD water pump pulley is has the v offset from the pump flange. On the Quantum it is installed so the V is closer to the engine block. When installed on the 1Z/AHU, it needs to be installed so the V is out away from the shaft flange in order to line up with the v-belt part of the 1Z/AHU crank sprocket. Anyway, it fits and woks great and is an option if want to run alt, A/C and water pump without the P/S.
CRSMP5:
thanks for confirming libby.. what i kinda expected to do on my 84 coupe.. just never gotten to that build..
one more odd ball split.. problem is holes.. usa westy power steering rabbits got.. with old york ac comp..
alt ran off ac.. ac ran off crank, had the shim style at crank to adj that..
then they ran a split ps pully that was way goofy in diameter.. thats the ps system that if you sneeze you curb it..
the4ork:
what about the vr6 water pump pulley, Ive installed one on an ABA with a serp setup to delete the PS and can run a/c too.
the4ork:
here is one on a diesel:
libbydiesel:
The VR6 pulley won't work with A/C unless you get the Unobtainium CCW Water Pump.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
