Author Topic: 1.6TD k24 or T3 on AHU?  (Read 16640 times)
Reply #15April 16, 2013, 06:15:48 pm
the4ork
  • 331
Re: 1.6TD k24 or T3 on AHU?
« Reply #15 on: April 16, 2013, 06:15:48 pm »
I've also considered a vnt-15 with a 50trim wheel and compressor. That would be quite nice. Otherwise you can order an off the shelf turbo metics 50trim T3 and get it with a stage1-5 .36 or .48 hot side.
Reply #16April 18, 2013, 09:54:11 pm
CrazyAndy
  • 739
« Reply #16 on: April 18, 2013, 09:54:11 pm »
Sounds cool; do you know the A/R of the VW T3 off the top of your head?
Reply #17April 19, 2013, 04:30:29 am
« Reply #17 on: April 19, 2013, 04:30:29 am »
38?
Reply #18April 19, 2013, 04:47:07 am
« Reply #18 on: April 19, 2013, 04:47:07 am »
.36  vnt15 hotside is probably too small for 50 trim cold
Reply #19April 19, 2013, 03:01:48 pm
CrazyAndy
  • 739
« Reply #19 on: April 19, 2013, 03:01:48 pm »
That's kind of what I was thinking as well; might be efficient, but that doesn't matter when you've got that big of a trim cold side hanging off there pushing that much air.  That would make the turbine the limiting factor.  What would avnt15's A/R be anyway?
What about a vnt17?  They're big enough to hybrid with a vnt22 cold side, you think it would  handle a 50 trim?  IF not, than would a 45 trim compressor be better on the 15?
Reply #20April 19, 2013, 04:38:47 pm
« Reply #20 on: April 19, 2013, 04:38:47 pm »
The 17/22 hybrid will do 200+ whp and 320+ wtq all day long on a 1.9 ALH.....
Reply #21April 19, 2013, 04:58:14 pm
the4ork
  • 331
« Reply #21 on: April 19, 2013, 04:58:14 pm »
i doubt the .36 hotside is that limiting. the 1.8t k03 hotside has got to be about that size or smaller, and it pushes 180hp at 7k+ rpm with 5v per cyl!
Reply #22April 20, 2013, 07:20:45 am
« Reply #22 on: April 20, 2013, 07:20:45 am »
I don't know the ar of any vnt stuff and its not really comparable anyway cause they're different families of turbo. If what 8v says is true then it would work a vnt17 but I'd do the 22/17 first
Reply #23April 20, 2013, 07:22:55 am
« Reply #23 on: April 20, 2013, 07:22:55 am »
I agree the only thing ***ty about it is the ancient turbine wheel. But otherwise in gas applications its said to be good for 230 crank hp
Reply #24April 20, 2013, 07:33:23 am
« Reply #24 on: April 20, 2013, 07:33:23 am »
Reply #25April 20, 2013, 07:59:42 am
« Reply #25 on: April 20, 2013, 07:59:42 am »
The vnt15 and vnt17 have the exact same hot side.  The compressor size is different.  The turbine shaft of the 17 is stronger and consequently heavier - vnt15 shaft is cut down between the journal bearings presumably to reduce inertia.
Reply #26April 20, 2013, 08:58:59 am
« Reply #26 on: April 20, 2013, 08:58:59 am »
Interesting!
Reply #27April 20, 2013, 01:20:33 pm
the4ork
  • 331
« Reply #27 on: April 20, 2013, 01:20:33 pm »
after some searching, a k03 hotside is .36A/R, and i presume the turbine wheel is about as restricting as that of a t3.
but bear in mind you can get different stages of T3 wheels. if you find yourself at a limiting factor (after extensive dyno testing) you will be able to sacrifice a small amount of spool and go up on the stage of the turbine wheel. T3's come in stage 1 (stock) through 5 (more flow).
if it were me, and my goal was over 200 hp at the crank, i'd probably go with a stage 3 .36 a/r hotside, or if my goal is a daily driver id go .36 stage1
