Author Topic: Cheap low flow muffler\resonator?  (Read 11344 times)
Reply #15March 20, 2013, 07:41:22 pm
Rising
  • 385
Re: Re: Re: Cheap low flow muffler\resonator?
« Reply #15 on: March 20, 2013, 07:41:22 pm »
Dang it every post you make about that vnt makes me want mine on so bad.
Someone should start an exhaust Clip thread so everyone can post up their set up and others can get ideas for the sound they want.
Sent from my ThunderBolt using Tapatalk 2
I want a VNT too.. I just might have to get one.. See people making 180-200whp on the 1.9 TDI's with the 17/22 combos like its easy.
Make the thread!! I've got to make some errands later I'll take a sound clip of my exhaust note :)
Thread made ;D if I put it in the wrong section feel free to move it! Also, if it takes off, sticky that beast! And I'll forever be a part of diesel history!! Hahaha.
But what Burns me up about the vnts is that I have one sitting in my garage and a turbo motor in my car begging for boost. I just have to get all the other bits together >:(
Mines only a 15 but id love to see what a 17/22 would do on one of these motors! Although I'd be scared to drive my 1900 lbs. Rabbit with 200whp. Haha. If I can hit 100 I think I'd be in a rocketship compared to now.
« Last Edit: March 20, 2013, 07:43:11 pm by Rising »
'84 Rabbit Diesel- 1.6D Stock
Reply #16April 28, 2013, 05:38:31 am
homerj1
  • 433
« Reply #16 on: April 28, 2013, 05:38:31 am »
Here is the muffler I finally decided on. Some of the Audi A6 guys are running these and they sound pretty good.
http://www.magnaflow.com/02product/displayapplications.asp?partnumber=10415
Duals of the above on a Audi A6
http://www.youtube.com/watch?v=K4WA6hjyxwA
The sound seems very European sports car-like. And raspy on the top end
« Last Edit: April 28, 2013, 07:49:16 am by homerj1 »
Reply #17April 28, 2013, 11:02:00 am
« Reply #17 on: April 28, 2013, 11:02:00 am »
Interesting. What's it look like on the inside? Is it packed with something or is it hollow? Their website doesn't give up too much information. I'm interested to know what it sounds like on a 1.6 turbodiesel. Maybe you could post a follow-up video when it's installed.
Reply #18April 28, 2013, 01:09:14 pm
« Reply #18 on: April 28, 2013, 01:09:14 pm »
It looks like a perforated tube inside, and Magnaflow packs with rockwool.
Reply #19May 02, 2013, 12:07:32 pm
« Reply #19 on: May 02, 2013, 12:07:32 pm »
Magnaflows either burn out, or clog with soot..
they also crack from all the vibration..
Reply #20May 03, 2013, 01:58:38 pm
« Reply #20 on: May 03, 2013, 01:58:38 pm »
Never had a problem with either, but I have seen  rub through form scraping on pavement.  Muffler worked fine after  a patch welded on.
Rockwool  is good to about 4X the temp of fiberglass, but I suppose you coiuld use space shuttle ceramic if your post turbo EGT is that high....
Temperature limits of some common insulation materials are indicated in the table below:
Insulation Material    Temperature Range
Low    High
(oC)    (oF)    (oC)    (oF)
Calcium Silicate    -18    0    650    1200
Cellular Glass    -260    -450    480    900
Elastomeric foam    -55    -70    120    250
Fiberglass    -30    -20    540    1000
Mineral Wool, Ceramic fiber          1200    2200
Mineral Wool, Glass    0    32    250    480
Mineral Wool, Stone    0    32    760    1400
Phenolic foam              150    300
Polyisocyanurate or polyiso    -180    -290    150    300
Polystyrene    -50    -60    75    165
Polyurethane    -210    -350    120    250
« Last Edit: May 03, 2013, 02:03:00 pm by 745 turbogreasel »
Reply #21May 07, 2013, 07:18:31 am
Rising
  • 385
« Reply #21 on: May 07, 2013, 07:18:31 am »
Homer if you do end up with one of these on a 1.6td please post it up in the exhaust note thread. I'd love to hear one of those not on a Gasser.
Reply #22May 07, 2013, 11:09:18 am
« Reply #22 on: May 07, 2013, 11:09:18 am »
Hmmm, I was hoping to find something like that Magnaflow muffler but hollow, no packing.
Reply #23May 08, 2013, 02:30:31 am
homerj1
  • 433
« Reply #23 on: May 08, 2013, 02:30:31 am »
Will do!  I actually bought the magnaflow, but am caught up in yard work at the moment - so no install yet :(
Reply #24May 13, 2013, 06:52:38 pm
« Reply #24 on: May 13, 2013, 06:52:38 pm »
Cherry bomb glass pack. I have used them on 1.6 NA, 1.6 TD and my 1.9 M-TDI. Beautiful :).
2.25 SS turbo back. :)
